Thread: DPF issue after Remap / EGR Removal
  1. DPF issue after Remap / EGR Removal
    Feb 2012
    Worcester
    Hi All,
    I have a 2.0L TDI which i recently had remapped (along with EGR removal) after the emissions update had decreased the cars performance and fearing a dreaded EGR failure.
    Now at about every 400 miles like clockwork the DPF light appears along with a higher idling RPM and the fan running. My mileage is around 35 miles daily so i presume i am giving the car enough of a run out.
    Is it possible this has been caused by the Remap/ EGR removal or just unfortunate coincidence? I have contacted the company who have done the remap and they seem to think i need a DPF removal (something i am reluctant to do.)
    Any help would be greatly appreciated.
  2. Re: DPF issue after Remap / EGR Removal
    May 2012
    Everywhere
    308 Post(s)
    Yes you need dpf removal as a working egr is a prerequisite of dpf regeneration it helps regulate both the pressure and temperature .
    The remappers should of known this , who are they ?
    So the options are Stage 1 remap file keeping egr software or dpf delete and relevant Stage 1 dpf & egr out .
    I guarantee you a genuine mpg gain with the dpf gutted , also as you may or may not know about the egr benefits of turbo spool , cleaner oil and cleaner induction inlet , full oxygenated combustion , egr causing incomplete combustion , etc .
  3. Re: DPF issue after Remap / EGR Removal
    Feb 2012
    Worcester
    Okay thanks for the info!
    I'd prefer to keep the DPF so if I ask that the remap be updated to program the EGR back on this should (hopefully) solve the problem?
  4. Re: DPF issue after Remap / EGR Removal
    May 2012
    Everywhere
    308 Post(s)
    Yes Stage 1 file keeping egr and dpf .
  1. Remap removal
    By MC09PJC in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-07-2015, 09:25 PM
  2. Remap - EGR Delete - DPF Removal....
    By shub7 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-09-2013, 06:29 PM
  3. Question Remap and dpf removal recommendation ....
    By nabzz in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-08-2012, 11:34 PM
  4. DPF Removal & remap - 3.0 TDI
    By Grant3.0tdi in forum 3.0TDi - Engine
    Last Post: 04-01-2011, 01:10 PM
