Thread: Power steering fluid leak?
Results 1 to 9 of 9
  1. Power steering fluid leak?
    Aug 2017
    West Midlands UK
    11 Post(s)
    How many possible places/seals/hoses can the power steering fluid leak from at the pump? I have a few spots of red PSF making their way from under the engine shield at the front right hand side of the car, it looks like the pump is located behind a cover there.
    Is it a big job to get at or just top off and ignore until it gets worse?
    2003 A6 C5 2.5 TDI Quattro Avant (180bhp)
  2. Re: Power steering fluid leak?
    May 2012
    Everywhere
    308 Post(s)
    PSF should be green .
  3. Re: Power steering fluid leak?
    Aug 2017
    West Midlands UK
    11 Post(s)
    Hmmm.... this is definitely red and right beneath the pump.
    I've never seen green PSF in my entire motoring and working career of 27 years, I was a Vauxhall main dealer mechanic back in the 90's and it was always red, It's my first Audi though so expect a few differences, I'll try and dip the tank and see what it has in it.
  4. Re: Power steering fluid leak?
    May 2012
    Everywhere
    308 Post(s)
    As far as I know it should be CHF11S .
  5. Re: Power steering fluid leak?
    Nov 2016
    Swindon
    13 Post(s)
    Are you sure is from the power steering? open the reservior and check. it might be an engine mount split (they are filled with oil)
  6. Re: Power steering fluid leak?
    Mar 2016
    Minervois, France
    54 Post(s)
    Quote Originally Posted by Stavros_Davros View Post
    We're never too old to learn
    If you have an automatic gearbox it could be fluid from that. It uses Dexron ATF, which is red, and used by many vehicles for their power steering. Audis use Audi/VAG hydraulic oil, which is green, as mentioned.
    Of course, someone else with long experience of power steering systems could have filled the system with Dexron without checking the car's specs, which could explain the leak.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  7. Re: Power steering fluid leak?
    Aug 2017
    West Midlands UK
    11 Post(s)
    Quote Originally Posted by Chema.RB View Post
    That's very interesting and another new thing learned - thanks!
    Do you think an engine mount going would give a loud bang at speed if it failed? In another thread I posted that during a 70 mph test drive I had a loud bang come from what sounded like the rear of the car or the rear diff but can't find any problem since checking visually, someone suggested it might be a rear coil spring snapped but they're seemingly fine.
    The engine does seem to rock the whole car from side to side when its revved when stationary and I get a horrible shaking at 70 - 80 mph although the wheels are all balanced and sorted.
  8. Re: Power steering fluid leak?
    Nov 2016
    Swindon
    13 Post(s)
    power steering fluid is green and "smells fishy"... XD
  9. Re: Power steering fluid leak?
    Aug 2017
    West Midlands UK
    11 Post(s)
    Thanks for the info, the PSF is indeed a browny/green colour and honks like you suggested.
    I did the left foot brake/accellerator trick to rock the engine which only moved 20mm max and then got under the covers for a good visual, the mounts were dry as a bone and in fairly good shape.
    I pulled the left fog lamp grill off and there it was... some A-Hole had stuffed a rag under the corner of the radiator to stop a leak, it was red anti freeze that had congealed that was weeping out of the engine guard.
    Must have been the dealer my brother bought the car from a few years ago because he would never do something so shoddy.
    How difficult is it to change a radiator out? It's not a worry yet as it's not losing much but my bro said it would need maybe 200ml topping up per year.
    I'll wait til it blows, like my old Zafira - hope it only costs £27 to replace like that did! I wish...
  1. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  2. Please Help Power steering fluid leak
    By Jam__GTI in forum Golf MK4 - 1999 - 2004
    Last Post: 24-02-2011, 03:41 PM
  3. Please Help Power Steering Fluid Leak
    By AJG in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-12-2009, 11:13 PM
  4. Power steering fluid leak
    By Boblell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-07-2009, 10:29 AM
  5. Please Help Power steering fluid leak!
    By benwb in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 01-07-2009, 09:25 PM
