Thread: Lemforder or Febi
Results 1 to 10 of 13
  1. Lemforder or Febi
    Jul 2013
    76 Post(s)
    Are Febi lower control arms similar to the Lemforder arms for quality?
    Dan
    2009/2010 2.0 TDIe SE
  2. Re: Lemforder or Febi
    May 2012
    Everywhere
    308 Post(s)
    Probably not .
  3. Re: Lemforder or Febi
    130 Post(s)
    1972 Post(s)
    Febi are good but not quite as good as Lemforder and also TRW are excellent. Meyle make some seriously good heavy duty versions that outlast anything else. Febi do lovely kits and the price is good against the quality and I have no qualms using them, we fit a huge amount of their products and very very rarely get a problem.
    1 1 0
  4. Re: Lemforder or Febi
    Jul 2013
    76 Post(s)
    Thanks Crasher.
    I will go with the Febi arms.
    Dan
  5. Re: Lemforder or Febi
    Mar 2009
    Montenegro
    13 Post(s)
    How many km /miles you have on car? Is it first time that you are changing arms? I would prefer Lemforder (this is oem supplier). Anyhow, I suppose that in UK you can safely buy any part without fear that is fake, in my country is not the same case unfortunately...
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  6. Re: Lemforder or Febi
    130 Post(s)
    1972 Post(s)
    Quote Originally Posted by dan2485 View Post
    If you would like me to quote you, just send me your reg by PM.
  7. Re: Lemforder or Febi
    Jul 2013
    76 Post(s)
    Thanks, but I have already ordered them.
    Dan
  8. Re: Lemforder or Febi
    Jul 2013
    76 Post(s)
    Quote Originally Posted by Novica View Post
    I have done 159,000 miles, i'm changing the left hand side as my 4 wheel alignment sheets are showing the camber is nearly going out of tolerance on the left hand side.
    I did have new upper arms fitted and they were on the car at the last alignment.
    The readings show that the bushes have worn causing the inside of the tyre to have the limit of the camber at 1 degree and 31 minutes compared with last years aligment of 1 degree and 10 minutes (ideal seting would be 1 degree and 7 minutes for each side).
    Dan
  9. Re: Lemforder or Febi
    Mar 2009
    Montenegro
    13 Post(s)
    Do you have some play on the arms? Are they making noise on rough road?
    How often do you make alignment?
    I bought the car 2 years ago and I did not make any alignment until now. So far, the car is handling good and I do not hear any noise from suspensions. But these should not be the reason to check it, I suppose.
  10. Re: Lemforder or Febi
    Jul 2013
    76 Post(s)
    I had a lot of tyre wear on the inside of the tyre.
    I did replace a worn track rod end and the C links were worn, this why I had the alignment redone.
    Its not wheel bearing related as I have replaced all the wheel bearings on the car before the last wheel alignment.
    As as the other side is ok it is not the subftrame bushes.
    The tracking on on the front was spot on at 0 degrees an 10 minutes for both sides.
    Dan
  1. Track Rod Ends Ocap or Lemforder
    By GMul4d in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-09-2016, 11:03 PM
  2. Coolant Temp Sensor Febi
    By gavsman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-06-2011, 02:56 PM
  3. Febi Bilstein Parts
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 16-04-2008, 01:10 PM
  4. Which control arms meyle, febi, vag ?
    By jemthetaxi in forum Passat - Archive Topics
    Last Post: 17-03-2007, 08:51 PM
  5. Which Control Arms,meyle..febi..vag ?
    By jemthetaxi in forum Archive posts
    Last Post: 11-03-2007, 11:24 PM
