Thread: V belt size to bypass Air Con compressor
  1. SOLVED: V belt size to bypass Air Con compressor
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Issue
    The air con compressor pulley shaft has cracked so I
    need to fit a new compressor as the shaft is part of the end casing. I can't do this until next weekend and need the car for work.
    The damage
    Pulley bearing has failed, circlip has been forced out of its groove on the shaft and the spring clutch has broken away (all 3 spring pieces).
    Cracking will soon lead to a sizeable piece of the shaft breaking off at which point the pulley would have come off and a bigger mess would have ensued. Caught it in time to avoid that and I have a good used identical compressor waiting to go on next weekend (have to degas AC system first though).
    Meanwhile the QUESTION
    Can I temporarily bypass the AC compressor by fitting a smaller V belt between the crank and alternator and if so what size does it have to be (part numbers of decent brands would be useful) and would I still be able to use the tensioner or do I have to remove it e.g. if a stretch belt can be used like those on non AC common rails? Mine is a PD of course.
    All help greatly appreciated.
    Mad Mitch
  2. Re: V belt size to bypass Air Con compressor
    Jul 2015
    Staffs
    46 Post(s)
    Run a piece of string around to get a rough size.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: V belt size to bypass Air Con compressor
    Jan 2012
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by rowdy-999 View Post
    Thanks but I was looking for a more off the shelf kind of solution. I have the rough measurements by running a garden wire around the circuit but the tensioner pressure is based on the longer belt fed over the ALT then down to the AC compressor. Shortening the circuit might put more strain on the alternator pulley if the existing tensioner is used on too short a length belt. I have seen ETKA diagrams with a belt from crank to alternator (overlaid on the diagram for the normal AC incorporated circuit) but could not find any more info on it.
    Solved: Mate of mine just rang and said the PK950 belt is the one I need specifically for a BMR without AC as there is no layout difference. Have one at ECP for a tenner so off there at the crack of dawn tomorrow.
    Mad Mitch
  4. Re: V belt size to bypass Air Con compressor
    Apr 2015
    Bedford
    6 Post(s)
    Quote Originally Posted by DMitch16 View Post
    Handy to know, will get one my self just in case I have that problem for a £10 is worth having as spares
  5. Re: V belt size to bypass Air Con compressor
    Jan 2012
    10 Post(s)
    88 Post(s)
    The one they gave me was PK948 but 2mm won't make any difference with the tensioner there. Working a treat and still have the ECON air flow inside just no AC.
    Mad Mitch
  1. bypass delete ac pump belt
    By patientx in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-03-2016, 10:43 PM
  2. Polo 9N - Drive belt reliability (correct size?)
    By GUEST 9999 in forum Polo - Derby - Lupo - Fox
    Last Post: 03-01-2016, 04:51 PM
  3. Please Help Clicking / Tapping from A/C compressor following belt changes
    By dale_jw in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-07-2013, 05:13 PM
  4. Replies: 4
    Last Post: 14-03-2013, 08:23 PM
  5. 1.2 Polo belt tensioner - torx size?
    By Gordonjcp in forum Polo - Derby - Lupo - Fox
    Last Post: 26-09-2009, 01:54 PM
