Thread: 2005 Touran 2.0tdi Central locking issues
  1. 2005 Touran 2.0tdi Central locking issues
    Aug 2008
    Isle of Skye
    Hello, I posted here a while back with the same question but had no reply. The issue is that the drivers door, front passenger door and rear drivers side door will not lock / unlock with the key or the button on the drivers door. The tailgate and the rear passenger door work perfectly. There are quite a few fault codes related to these doors but would like some expert opinion as to what remedial action IO may need to take. Here is the full VCDS scan:
    Tuesday,13,June,2017,15:15:55:00007
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170320 DS267.7
    Ross-Tech: Home
    VIN: WVGZZZ1TZ5W130978 License Plate: CV05WLK
    Mileage: 239270km-148675mi Repair Order: central locking
    Chassis Type: 1T (1K0)
    Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
    VIN: WVGZZZ1TZ5W130978 Mileage: 239270km-148675miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.clb
    Part No SW: 03G 906 016 BQ HW: 028 101 190 6
    Component: R4 2,0L EDC G200SG 6254
    Revision: 12345678 Serial number: VWZ7Z0E1538751
    Coding: 0000072
    Shop #: WSC 01286 386 08256
    VCID: 73EE026712B52FD9E4-8026
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0023238
    Shop #: WSC 00488 210 71784
    VCID: 3A70EF43755F9E91E7-806E
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No: 1K0 907 044 AB
    Component: ClimatronicPQ35 066 0404
    Shop #: WSC 00000 000 00000
    VCID: 67D66637566DD37948-8032
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
    Component: Bordnetz-SG H34 0803
    Revision: 00H34000 Serial number: 00000001435401
    Coding: 01890F020004100000120C000000000000087F075C
    Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer VW358 012 0401
    Coding: 00065493
    Shop #: WSC 00000
    Address 15: Airbags Labels: 1T0-909-605.lbl
    Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
    Component: 02 AIRBAG VW62 0506 1500
    Revision: 09025000 Serial number: 0038BD0BCVGJ
    Coding: 0012338
    Shop #: WSC 01324 785 00200
    VCID: 356AFC7F5C4171E90A-8060
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
    Component: Lenksäulenmodul 021 0050
    Coding: 0000042
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1T0 920 961 A
    Component: KOMBIINSTRUMENT VDD 0814
    Coding: 0003403
    Shop #: WSC 00488 210 71788
    VCID: 3162C86FA8295DC956-8064
    Address 18: Aux. Heat
    Cannot be reached
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H11 0110
    Revision: 11 Serial number: 29001051240134
    Coding: 3D3F1340078003
    VCID: 2952200F80F925099E-807C
    1 Fault Found:
    01207 - Control Module for Auxiliary Heater (J364)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 12
    Reset counter: 21
    Mileage: 239278 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:57:35
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 0814
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1T0 959 701
    Component: Tuersteuergeraet 09 0158
    Coding: 0000116
    VCID: 74EC017B17BB28E1FD-8020
    2 Faults Found:
    01552 - Motor for Central Locking; Drivers Door (V56); Lock
    012 - Electrical Fault in Circuit
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    008 - Implausible Signal
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
    Part No: 1K2 909 144 H
    Component: EPS_ZFLS Kl.6 1502
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 BL
    Component: 01 KSG 0301
    Coding: 81E802087F2D8505485FC61011
    VCID: 7BFE2A473AE56799BC-802E
    Subsystem 5 - Part No: 1K0 947 291 F
    Component: Innenraumueberw.009 4809
    Coding: 00000000
    Shop #: WSC 00000
    Subsystem 6 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H02 1301
    Subsystem 7 - Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    3 Faults Found:
    01134 - Alarm Horn (H12)
    00931 - Locking Module for Central Locking; Rear Right (F223)
    01038 - Central Locking Thermal Protection
    000 - -
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1T0 959 702
    Coding: 0000116
    VCID: 75EA3C7F1CC131E9CA-8020
    2 Faults Found:
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No SW: 1K0 035 186 P HW: 1K0 035 186 P
    Component: Radio FO3 013 0014
    Revision: 00013000 Serial number: VWZ7Z2E0099539
    Coding: 0040400
    Shop #: WSC 00401 210 88517
    VCID: 336EC26752356FD924-8066
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
    Part No: 1K0 959 703 B
    Component: Tuersteuergeraet 06 0214
    Coding: 0000048
    VCID: 2F66CE17BE1D4B3940-807A
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
    Part No: 1K0 959 704 B
    Coding: 0000048
    VCID: 3064CD6BA32354C159-8064
    End-------------------------(Elapsed Time: 01:55)--------------------------
  2. Re: 2005 Touran 2.0tdi Central locking issues
    Mar 2007
    Brum
    best thing to do is to search the Ross Tech Wiki page for your fault codes and see what they mean. The Wiki pages often have suggested repairs which can range from checking wiring and connectors to changing physical components.
    2007 VW Touran Sport 2.0 TDI
    Pumpkin Android headunit
    1990 Mk2 Golf Driver 1.6, 1999 Passat SE 1.9 TDI, 2006 Passat Sport 2.0 TDI and 2012 Passat Est Sport 2.0 TDI - all gone but not forgotten.
  3. Re: 2005 Touran 2.0tdi Central locking issues
    Aug 2008
    Isle of Skye
    Quote Originally Posted by Scottiedogg View Post
    Thanks. I have concluded that it is most like 3 defective locks, or 3 x defective wiring looms, or both. I will do more investigating, but will probably order 3 new Chinese locks from eBay as they are only £20 each and have a warranty. I previously replaced one lock on this car already and it is the only one currently working!
  4. Re: 2005 Touran 2.0tdi Central locking issues
    Jul 2015
    Staffs
    46 Post(s)
    Is there a control module for the central locking? Maybe change that first...doubtful 3 locks are playing up.
    Also worth checking where the wiring enters the doors inside that rubber tube....wires often break.
    Ian
    A4 B6 Avant Nogaro Blue
  5. Re: 2005 Touran 2.0tdi Central locking issues
    Mar 2007
    Brum
    I believe there's a control module within each door. Certainly for the front doors this is held within the window regulator mechanism - prob the same with the back doors but will need checking. I've currently got an issue with my front passenger door lock too but I can't even get mine open! Got another thread open for that and hoping to get some suggestions on there soon.
  1. Replies: 21
    Last Post: 23-09-2017, 12:51 PM
  2. 2005 Touran 2.0tdi door lock / central locking issues
    By skyegtb in forum Touran - Sharan - Caravelle
    Last Post: 04-04-2017, 11:03 AM
  3. help please vw touran 09 central locking problem
    By nrc in forum New Member Introductions
    Last Post: 14-10-2013, 08:23 PM
  4. Please Help Passat B6 2.0tdi Sport 2005, glowplug issues
    By dutchy21uk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-06-2011, 06:08 PM
  5. touran central locking
    By tractor fixer in forum Touran - Sharan - Caravelle
    Last Post: 08-05-2010, 09:47 PM
