Thread: Front Near Side Lower Wishbone Replacement, DSG Gearbox !
Results 1 to 10 of 15
  1. Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    Jun 2016
    Guys
    Need to replace front lower wishbones on my 2006 Passat 2.0 TDI DSG
    I have noticed the rear bush bolt is obstructed from being removed by the DSG box, any ideas on how this can be removed ?
    Many thanks in advance
  2. Re: Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    Dec 2014
    Bedford
    42 Post(s)
    Lower the subframe by losening 3 bolts or raise the gearbox.
  3. Re: Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    Jun 2016
    Is that straightforward ?
    cheers
  4. Re: Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    Dec 2014
    Bedford
    42 Post(s)
    Yes but I'm usually doing it on a ramp, you might need to do both if you are working with a jack and axle stands.
  5. Re: Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    129 Post(s)
    1972 Post(s)
    We lift the box, you get the same problem on the V5/6 Golf 5 with the sump and on 3 cylinder Polo platforms also because of the sump.
  6. Re: Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    Jun 2016
    Quote Originally Posted by FLAPPERJACK76 View Post
    HI
    When you say do both? what do you mean sorry ?
  7. Re: Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    Jun 2016
    Thanks for the advice, how do i raise the dsg box please ?
    By the way, my jerky dsg box is back now its getting warmer, its been perfect since the autumn !
  8. Re: Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Stick a jack underneath with a wood block and raise until it starts to resist which might be enough. Some slacken the NSF gearbox mount to increase the raised height but the dog bone rear gearbox mount will fight you if not disconnected from the subframe. You only need to raise the box enough for the bolt to be accessed.
    Loosening the subframe bolts (not removing them) may give more clearance but the subframe bolts are normally torque to yield stretch type so should really be renewed.
    Mad Mitch
  9. Re: Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    129 Post(s)
    1972 Post(s)
    With the car raised on a two post lift we disconnect the gearbox upper mount (new bolts MUST be used) then take the car up and lift the gearbox from below with a hydraulic transmission jack taking car out to trap or stretch anything.
  10. Re: Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    Jun 2016
    Thanks for the advise guys. Do not the engine mounts prevent the engine/gearbox rising up ?
    Is the upper gearbox mount easy to get to ?
  1. Question Rear suspension lower on one side, car sits lower?
    By thommo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-07-2017, 10:40 AM
  2. Snow + hill + Skid = snapped lower wishbone and deployment of both from airbags
    By Jackblack in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-01-2016, 11:12 PM
  3. OSF lower front wishbone replacement
    By wigs_1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2013, 09:00 PM
  4. Front lower wishbone rear bushes
    By Pezza in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-07-2010, 04:53 PM
  5. Bora 130 St - Oil Leakage Wishbone - Driver Side
    By COTT in forum Bora - 1998 - 2005
    Last Post: 22-02-2008, 06:13 PM
