Thread: Glow Plug Replacement - DIY job?
Results 1 to 10 of 13
  1. Glow Plug Replacement - DIY job?
    Sep 2016
    Wexford, Ireland
    So, our car became due for its 1st service in our care and I thought I'd treat ourselves to a main dealer job. After all, there's nothing wrong with it, except the blower working intermittently, which I asked them to check.
    Well how wrong I was! According to them, almost EVERYTHING is wrong with it!
    Anyway, one of the 'faults' is the glow Plug on cylinder 2 has "gone". Not sure where it's gone to exactly but still... Is it a DIY job to replace? :/
  2. Re: Glow Plug Replacement - DIY job?
    Jul 2015
    Staffs
    46 Post(s)
    What engine?
    Some 2.0s are under the cam cover, but its still a fairly straight forward job. Do all 4 (?6 if v6) on a warm engine, and you could spray some penetration oil around them (if external) a few days before.
    Replace with BERU who make OE variants.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: Glow Plug Replacement - DIY job?
    New Forest
    80 Post(s)
    It might be showing up on a scan as 'Open circuit' or some other fault code but it might not actually be duff.
    I was getting scans of 5 out of 6 being faulty but Ross-Tech suggested it might be the glow-plugs wiring harness.
    I think No.2 is one of the easier ones to replace on the 27TDi but as a previous poster said, what engine is it?
    If you do it yourself, beware breaking the plug top off, leaving a tricky removal job.
    Sent from my STV100-4 using Tapatalk
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  4. Re: Glow Plug Replacement - DIY job?
    Sep 2016
    Wexford, Ireland
    Sorry, I should have mentioned it's a 2009 2.0 tdi e (136 horses)
    I assume they did a bit of a scan but because I didn't pay extra for that, they didn't give me any print-out etc.
    EDIT: I've looked around the forum but can't find info on how to add a signature to my posts. Don't want to do anything too fancy, just add the car details.
  5. Re: Glow Plug Replacement - DIY job?
    Aug 2016
    Scotland
    Just make sure that if you do your self ....buy right ones. I bought from euro car parts and didnt look closely fitment details..bought for wrong engine code. After 2 start all 4 went They will fit but they work with different voltages. Otherwise easy..at least on my 2.0 tdi BRE. cam cover needed to come off.
  6. Re: Glow Plug Replacement - DIY job?
    Jul 2007
    glasgow
    35 Post(s)
    I would replace the 4 of them
  7. Re: Glow Plug Replacement - DIY job?
    Sep 2016
    Wexford, Ireland
    OK, I'll get stocked up with all 4 then.
    My engine number starts with "CAG" so assume that's the engine code.
    Any possible pitfalls with doing on this engine type?
  8. Re: Glow Plug Replacement - DIY job?
    Jul 2013
    76 Post(s)
    You have a CAGB engine.
    Use a long noise pliers to remove the leads, do not squash the leads.
    And make sure that you have a suitable long reach socket or a glow plug socket for the glow plugs.
    The new plugs need to be tightened to 17Nm.
    Dan
    2009/2010 2.0 TDIe SE
    1 1 0
  9. Re: Glow Plug Replacement - DIY job?
    Sep 2016
    Wexford, Ireland
    Thanks Dan. I'll get the plugs ordered.
  10. Re: Glow Plug Replacement - DIY job?
    Dec 2015
    Scotland
    11 Post(s)
    Can you please post back with a follow up, I'm due to do this job, do you need to remove the cam cover on yours? I think you are advised to replace the cam cover gasket on my car (bre 2tdi) if it is taken off?!
  1. glow plug replacement
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-12-2014, 12:17 PM
  2. Question glow plug replacement
    By danny851 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-02-2014, 09:26 PM
  3. Please Help Glow plug replacement
    By willc1985 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-09-2013, 10:14 AM
  4. Question Glow Plug Replacement
    By Dazzler01 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2012, 09:26 AM
  5. glow plug replacement
    By bagseye in forum Early Passat Forum - Pre 97
    Last Post: 22-03-2009, 10:13 PM
