Thread: A6 C6 Avant Rear washer problem
  1. A6 C6 Avant Rear washer problem
    Apr 2009
    Gurus of the Audi world, please can you assist.
    My A6 avant rear wiper was playing up, so I trawled through some remedials, unblocked the jets etc, then removed the boot trim to my horror found the little black coupling onto the motor leaks like a sieve.
    Wondering if there's a way around this, as the metal plate does have screws and also what looks like little black plastic shear pins.
    Im loathed to buy a whole new module, but if you gurus might be able to recommend a better solution to repair, I would be very grateful.
  2. Re: A6 C6 Avant Rear washer problem
    Jul 2015
    Staffs
    46 Post(s)
    It's probably knackered inside as well. Bite the bullet and get a new unit.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: A6 C6 Avant Rear washer problem
    Apr 2009
    I think you might be right, but the wiper seems to be operating correctly as long as I don't use the wash facility
  4. Re: A6 C6 Avant Rear washer problem
    May 2017
    Canterbury, Kent
    57 Post(s)
    I have a similarish problem with my A6 Avant (2007).
    At the moment, when you move the lever back to spray some water on the rear screen, nothing happens. Water then finds it's way into the n/s compartment where the sat nav DVD unit is housed and drips directly onto the silver housing!!! I've obviously stopped using it.
    I'm guessing either a pipe blockage, or more annoyingly a pipe pop-off (or even a blockage that has now led to a pipe pop-off?) - is there a how-to that can help me trace back the water line to see where the leakage is coming from? I guess that the only positive here, is that if the pipe is leaking directly into the sat-nav cubby hole, it hopefully won't be too far back from the back of the car!
    Many thanks!
  5. Re: A6 C6 Avant Rear washer problem
    Jul 2013
    76 Post(s)
    Quote Originally Posted by rjsdavis View Post
    Many thanks!
    There is a pipe union above the MMI/Radio units that is common to break check there first hence the wet electronics. If not fixed then it could damage the MMI equipment.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  6. Re: A6 C6 Avant Rear washer problem
    Contact your local dealer , it's a known issue.
    They will carry out the work foc, had mine done 18 months ago when I got the car, it's an 07 plate.
  1. Please Help Avant rear washer problem
    By d3m0n123 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-02-2015, 11:17 PM
  2. A6 Avant Rear Washer Problem
    By gilesharrison in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-02-2015, 12:27 PM
  3. Avant Rear Washer Problem
    By iainst26 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-02-2010, 11:35 PM
  4. A6 Avant - Rear washer jet problem and solution
    By paultyson in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-01-2009, 01:59 PM
  5. Avant rear washer and wiper problem...
    By maudi25 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2008, 04:19 PM
