Thread: Intake Manifold Flap faults
  1. Intake Manifold Flap faults
    May 2017
    Dublin
    So I have the following error codes when I scanned my A6 C6 4F 2.0 TDI 2006 year
    Address 01: Engine Labels: Redir Fail!
    Control Module Part Number: 03G 906 016 GC HW: 03G 906 016 GC
    Component and/or Version: R4 2,0L EDC G000CG 9642
    Software Coding: 0000076
    Work Shop Code: WSC 66565 257 00032
    VCID: 6A8C301BF07B378793D-803E
    Fault Codes have been Erased
    2 Faults Found:
    012546 - Motor for Intake Manifold Flap (V157)
    P3102 - 000 - No Signal - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 157808 km
    Time Indication: 0
    Date: 2017.05.13
    Time: 17:03:46
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00101000
    Torque: 0.0 Nm
    Torque: 300.1 Nm
    012545 - Motor for Intake Manifold Flap (V157)
    P3101 - 000 - Open or Short to Ground - MIL ON
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 157808 km
    Time Indication: 0
    Date: 2017.05.13
    Time: 17:03:46
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00101000
    Torque: 0.0 Nm
    Torque: 300.1 Nm
    Readiness: 0 0 1 1 1
    I decided to change the whole manifold flap unit aka the throttle body. Off course after replacing the flap and re-scanning, the faults were still there, so I cleared them. They came back almost instantly.
    After doing some research, I came to know that I need to replace either fuse 8 or fuse 24 in the fuse box located under the bonnet.
    The trouble is I DONOT have a fuse box under my bonnet. My battery is in the trunk. In my car, the fuse boxes are located the same as in this doc
    http://acislovensko.sk/wp-content/up...useList-EN.pdf
    Can someone please guide me where would the fuse location be for the intake manifold flap?
  2. Re: Intake Manifold Flap faults
    46 Post(s)
    Welcome.
    I suggest doing some reading and research as this topic is highly covered on the forum, in fact there is quite a large thread present here.
  3. Re: Intake Manifold Flap faults
    May 2017
    Dublin
    Quote Originally Posted by Chris View Post
    Welcome.
    Thanks Chris!! I did do some research on the forum and other forums but to no avail. I want to know the fuse location which everyone mentioned to be under the bonnet. But Its not the case with my car. I donot have a fuse box under the bonnet (so does I believe a lot of other a6 c6 4f's).
  4. Re: Intake Manifold Flap faults
    May 2017
    Dublin
    So it turns out that the new "used" manifold flap I bought was faulty too. Replaced it and the fault went away. Did not have to change any fuses.I have a BRE engine btw!!
  5. Re: Intake Manifold Flap faults
    Aug 2016
    Scotland
    Had problem with my Intake flap motor aswell (v157) i just took it apart ,cleaned ,disassembled motor it self. Cleaned brushes and bent little springs . Sorted. Just brushes worn out and get shorter and wont hold that much against rotor. Doing my thing and all good. Done same with EGR but have not tested it yet because bought used one before repaired it. And now have egr ready to go if get code again with secondhand replacement one. EGR was done before V157..Thats why i didnt buy new v157 as i saw that these things can be easily repaired.
  1. Question Intake Manifold Flap; Audi A4 B8
    By men8idw in forum VCDS - Help Requests
    Last Post: 28-02-2015, 08:13 AM
  2. Intake Manifold Flap
    By Borab0y in forum Golf MK5 - 2004 - 2009
    Last Post: 14-02-2015, 09:33 PM
  3. v6 tdi intake manifold flap fault
    By andreia in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-08-2012, 01:21 PM
  4. Intake manifold flap
    By john-mandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-12-2010, 11:48 PM
  5. Motor Intake Manifold Flap
    By daveaustin in forum Archive posts
    Last Post: 06-12-2007, 04:39 PM
