Thread: Audi A6 Door latch bounce
Results 1 to 8 of 8
  1. Audi A6 Door latch bounce
    Dec 2007
    8 Post(s)
    Can anyone confirm if the mechanical part of the latches are the same on front and rear doors, i.e. can a latch from rear door be used on front if the electrical unit is swapped over ?
  2. Re: Audi A6 Door latch bounce
    bristol
    10 Post(s)
    This happened to me the other day. Would only close when shut slowly. Cleaned up lock and sprayed with white grease. Seems all good. Also adjusted my strike plate so the door is nice and tight.
  3. Re: Audi A6 Door latch bounce
    Jan 2017
    Dublin
    Had the same problem with passenger door,my old lock had taken alot of punishment from people slamming the door
    replaced lock with scrappie one and adjusted the striker plate,my door needs to be lifted slightly and closed slowly as i think its from the door sagging on the hinge
    still doesnt close 100% properly unless i do it slowly
  4. Re: Audi A6 Door latch bounce
    Dec 2007
    8 Post(s)
    Do you still have the old faulty lock.
  5. Re: Audi A6 Door latch bounce
    Jan 2017
    Dublin
    No i dont,i gave it to somebody for parts they wanted of it,the jaws that attach to the striker plate had lots of damage from passengers slamming it
    Just see if your door is sagging slightly,you will see when its nearly shut,might be a couple of cms low
  6. Re: Audi A6 Door latch bounce
    Dec 2007
    8 Post(s)
    Thanks for replying, I was looking for an old unit for experimental purposes as I think I have found out what causes this bounce
    issue, but I need more research to confirm. Your door hinge situation may be improved by fitting shims at bottom of door between
    door frame and hinge, I also think that if the striker adjustment is used as a means to raise the door it will aggravate the bounce.
    Thanks again
    Michael.
  7. Re: Audi A6 Door latch bounce
    Jan 2017
    Dublin
    I must look into doing that,for now i just live with it and let the passengers out like a chauffeur ha!
    Let me know if you do figure out a reason for why it bounces,id be interested
    Christy
  8. Re: Audi A6 Door latch bounce
    Apr 2015
    Damascus, Syria
    Just something to try....remove the striker plate from the door piller entirely. Then check the door alignment, if it is not square 100% all round, it needs adjustment. With the door nearly closed, try lifting it up and down. If there is movement, it means that there is wear in the hinges..mainly the bottom hinge. You will need to remove the inner piller trim and loosen the lock, lift up the door, and tighten the hinge nuts. This will allow you to align the door correctly to the frame, then put the striker plate back on the piller and check the in -out movement of the door when it locks. As Michael says, using the striker plate to adjust the door is not a good idea...always use the hinge adjustment, and it may be necessary to replace the hinge if the wear is excessive... doing this will eliminate the door alignment from the possible cause of bounce. After that......microswitch in the lock as the problem ????
    Good Luck with it,
    Jim...
  1. A6 Drivers door latch
    By combover1066 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-02-2015, 06:13 PM
  2. Door won't open/close/bounce back if not closed very sotly
    By ametlib in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-12-2014, 12:13 AM
  3. Question door wont latch
    By djrodes in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-08-2010, 06:42 PM
  4. Door latch problem ???
    By tonyleach in forum Golf MK4 - 1999 - 2004
    Last Post: 16-10-2008, 02:22 PM
  5. GOLF MK 4 DOOR LATCH PROBLEM
    By st0ned in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-10-2006, 02:18 PM
