Thread: 2.5tdi v6 AKE -01 camshaft problems
Results 1 to 10 of 16
  1. 2.5tdi v6 AKE -01 camshaft problems
    May 2017
    Sweden
    Hi everyone.
    I have a Audi A4 Quattro from 2001 with some problem. It's really hard to start, runs really rough and white/blue smoke a lot. The problem is something with the intake valves at the right side cylinder head. I made a leakdown test through the injector and all air went out via the intake valves, but when I removed the camshaft it was sealed. It builds great pressure in the cylinder.
    Anyone got an idea of what the problem is?
    Regards from an clueless swede
  2. Re: 2.5tdi v6 AKE -01 camshaft problems
    131 Post(s)
    1973 Post(s)
    AKE cams and fingers suffer from terrible wear problems, sometimes so bad that I have seen three or four cam fingers thrown out into the head and just lying there.
  3. Re: 2.5tdi v6 AKE -01 camshaft problems
    May 2017
    Sweden
    the camshafts and fingers/rocker arms have recently been changed on both sides by the previous owner at a garage, meanwhile they lifted the right head and changed valves. The problem is that the valves don't close when the camshaft is mounted. But when I remove the camshaft the valves seal properly. Could the problem be something about the hydraulic tappets? I don't know if they also were changed or if they are old.
  4. Re: 2.5tdi v6 AKE -01 camshaft problems
    131 Post(s)
    1973 Post(s)
    Is it both sides where the valves do not close? You could do with finding out what was fitted, part numbers/make
  5. Re: 2.5tdi v6 AKE -01 camshaft problems
    May 2017
    Sweden
    Only the right head leaks, don't know if exhaust valves leaks since I haven't taken of the exhaust manifold but I don't think they leak. The cams are bought on eBay but are supposed to fit the AKE engine. I don't want buy new cams because they cost over 1700€ in sweden, and that's about how Much the car is worth in good condition.
  6. Re: 2.5tdi v6 AKE -01 camshaft problems
    131 Post(s)
    1973 Post(s)
    It could be that the wrong profile cams or followers have been fitted.
  7. Re: 2.5tdi v6 AKE -01 camshaft problems
    May 2017
    Sweden
    Do you know the dimensions on the cam? I have searched a lot but haven't found anything.
    Maybe when the garage fixet the head they regrinded the valveseats so now the valves gets too long? I will try to compare to the other head.
  8. Re: 2.5tdi v6 AKE -01 camshaft problems
    May 2017
    Sweden
    Are the intake and exhaust sides using the same tappets and fingers? Or are they supposed to look different?
  9. Re: 2.5tdi v6 AKE -01 camshaft problems
    131 Post(s)
    1973 Post(s)
    All 24 are the same BUT there are two different designs of cam, equaliser and finger.
  10. Re: 2.5tdi v6 AKE -01 camshaft problems
    May 2017
    Sweden
    are the diameter of the camshaft supposed to be different on exhaust and intake lobes? Intake diameter 34mm and exhaust 33mm
  1. TFSi Camshaft problems - anyone heard of this?
    By garmcqui in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 13-03-2016, 06:50 PM
  2. Question regarding 2.5 tDi Camshaft problems
    By JGP in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-02-2013, 10:57 AM
  3. 2.5tdi severe camshaft wear
    By shabazmo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-12-2010, 01:04 PM
  4. A6 5cylinder 2.5tdi broken camshaft
    By drwint in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 21-10-2010, 08:23 AM
  5. Question Camshaft chain sprocket problems
    By happy2 in forum Touran - Sharan - Caravelle
    Last Post: 04-10-2010, 02:26 PM
