Thread: Manual gearbox oil spec for B8
  1. Question Manual gearbox oil spec for B8
    Sep 2015
    Scotland
    Hi All,
    Just a quick question,
    I'm looking for the correct Audi spec and viscosity for gearbox on on an A4 B8 2009 2.0tdi, 105KW CAGA spec engine. Its got the standard 6 speed manual trans.
    Best I've been able to find says 75W90 full synthetic, but doesn't actually list what audi spec it needs to meet. Phoning up Audi they keep saying that its "Sealed for life" but after a bit of discussion they mentioned that "life" actually means 100,000 miles .
    I was also assuming i'll need around 5 litres for the refill?
    Any help is appreciated.
  2. Re: Manual gearbox oil spec for B8
    May 2012
    Everywhere
    308 Post(s)
    You must find out the correct VW spec number eg G 052 911 , 75W90 is good for track thick but can hinder cold shifting . Better is 75W80 or thinner .
    Go back and ask for the spec and also phone TPS to double check .
  3. Re: Manual gearbox oil spec for B8
    Jan 2018
    Waterlooville
    Hi Tonysco,
    Did you find out the spec? I have exactly the same motor as you and since I'm getting the clutch, flywheel and crank seal done on Wednesday I want to change the gear oil too.
    TIA.
  4. Re: Manual gearbox oil spec for B8
    May 2012
    Everywhere
    308 Post(s)
    It's either going to be Fuchs Titan Sintofluid SAE FE 75W
    ( G 052 171 ) or
    Fuchs Titan Sintofluid SAE 75W-80 ( G 052 911 )
  5. Re: Manual gearbox oil spec for B8
    Sep 2015
    Scotland
    Quote Originally Posted by Patto275 View Post
    Hi Tonysco,
    TIA.
    Hi there,
    I gave up trying to get the spec from Audi, i phoned 3 dealerships and all said its a sealed unit and cant be serviced.
    However i also sent a quick e-mail to Opie oils and in 30 mins they came back with this;
    Pardon Our Interruption
    I bought 5L from my LLN gearbox, but it ended up just taking 4. Easy enough to change when you have the car raised and level.
  1. Question 5 speed manual gearbox oil spec - stiff shifts when cold
    By the sheep in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-12-2016, 02:25 PM
  2. 2.0 tdi Gearbox Transmission oil spec & amount for GYX gearbox ?
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-09-2015, 03:08 PM
  3. Audi A6 2006 2.0TDi BRE Multitronic Gearbox Oil Change ATF Spec
    By sam2k01 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-04-2014, 09:32 PM
  4. Please Help a4 s line diesel manual 2010 plate fan staying on !! / a4 s line special addition spec ??
    By garry5510 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-02-2012, 06:36 PM
  5. Tiptronic gearbox oil spec
    By andythechief in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-04-2010, 12:28 PM
