Thread: Brake warning lights on after brake change?
Results 1 to 10 of 13
  1. Brake warning lights on after brake change?
    Feb 2017
    Hi all,
    I had the "brake pads worn" come up on DIS every time i started the car since about 2 weeks ago and the yellow brake symbol would light up and stay on.
    I changed the rear pads last week and to my annoyance they had 70% left on them! The light was still on, so I changed the fronts over the weekend and again, 70% left! Changed the wear sensors, used Ferodo OEM pads but every time I start the car DIS keeps displaying "brake pads worn" and the yellow lights stays illuminated for the journey.
    Any ideas?
    Thanks!
  2. Brake warning lights on after brake change?
    Jun 2015
    West Yorkshire
    Did you use genuine sensor kit?
    Also did you plug everything back in
  3. Re: Brake warning lights on after brake change?
    Pembrokeshire
    22 Post(s)
    dodgy connection somewhere in one of the wires. theres 2 wires per sensor, and electric has to be able to flow down one and back up the other. any breaks or poor connections and the warning light comes on.
  4. Re: Brake warning lights on after brake change?
    Dec 2014
    Bedford
    42 Post(s)
    I use an old safety pin thats been grounded on a grinder i work it back and forward in the terminals on the loom to the pads and that usually fixes it .
  5. Re: Brake warning lights on after brake change?
    Feb 2017
    Used the OEM spec Ferodo kit which came with new sensor and wires, so connected everything up and made sure it was all secure. Could try and clean up the terminals with some sand paper. Wonder why the light came on so early though as the brakes weren't even close to 50% worn when it came up.
  6. Re: Brake warning lights on after brake change?
    Pembrokeshire
    22 Post(s)
    as i said, dodgy connection somewhere.. soon as a wire isnt 100% connected , the light comes on.
  7. Re: Brake warning lights on after brake change?
    Feb 2017
    Cheers, will give it a wiggle! I found it odd that despite the complexity and amount of information available in modern cars like these, that they can't show whether it's the front or back that is "worn". Would certainly speed up diagnostics!
  8. Re: Brake warning lights on after brake change?
    Pembrokeshire
    22 Post(s)
    pad warning light comes on, inspect brakes. if it said fronts then you wouldnt check the rears.. they shouldnt really be relied upon anyway, usually only on one pad per side, sometimes only one pad per end, so if another pad wears out first, or a caliper or slide is jammed then it ends up costing you a set of discs as well. best to do a visual check yourself every so often. inner pads can usually be checked using a small miror on a stick and torch, through the spokes on the alloys.
  9. Re: Brake warning lights on after brake change?
    Dec 2010
    Worcestershire
    Same problem I've got. It's looking like a wire problem in the loom from the sensor connector to ....wherever it goes.... on mine. If I drive only in a straight line it doesn't come on, but if I turn (especially left) then the beep and symbol appears ��
  10. Re: Brake warning lights on after brake change?
    Apr 2014
    Derby
    30 Post(s)
    When I had this, I changed the front pads and sensor, but light was still on. Spent ages fault finding etc, to discover rear pads had worn down at the same time. Changing rear pads and sensor cured it.
    Current Fleet
    2017 Audi A6 Avant BiTdi
    2008 BMW Z4M Roadster
    2003 Clio 172 Cup
  1. Question Engine warning and parking brake warning lights on at same time
    By ajh in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-05-2010, 05:33 PM
  2. Brake & ABS & ASR Warning Lights On...
    By A62.5TDIV6 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-05-2009, 08:38 PM
  3. Please Help ESP, ABS and BRAKE Warning Lights!
    By Uxair in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2009, 10:39 PM
  4. Brake lights ESP and ECU warning
    By jsbarcs in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2009, 01:27 AM
  5. warning lights abs and brake
    By r1ytm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2008, 09:50 PM
