Thread: Front brake pad sensor wiring
Results 1 to 9 of 9
  1. Front brake pad sensor wiring
    Dec 2010
    Worcestershire
    Does anyone know where the front pad warning wiring goes to? It seems to disappear into the engine bay....
    My warning light comes on (turning left usually triggers it). Front pads are fine, I've replaced the sensor, and replaced the rear pads that were low-ish. I can only surmise that there is a dodgy connector or break in the wiring harness. Just need to find the other end to test.
    All hints and tips gratefully received.
  2. Re: Front brake pad sensor wiring
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    When Audi did my rear pads couple months ago they said that I had corrosion on the front wiring harness for the pad wear sensors and ABS sensors, they listed a repair harness for about £70. I will have a look through my paperwork later to see if I can find it. In my case it wasn't a corroded harness they just left one of the sensors unplugged.
    The sensors appear to be a loop of wire that breaks connection when worn through. So try a known bit of good wire and plug it into sensor plug to see if fault goes.
    I had a slight lip on my discs and it was enough to wear away the wire and trigger the fault. I replaced my pads with Bosch ones from eurocarparts and they came with new pad wear sensor.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  3. Re: Front brake pad sensor wiring
    Dec 2010
    Worcestershire
    I've already fitted a new sensor (although it turns out there was nothing wrong with the old). The problem is with the wiring that the sensor plugs into that disappears into the engine bay. I need to find the other end of it to be able to test....anyone know where it goes?
  4. Re: Front brake pad sensor wiring
    Jan 2016
    Sweden
    Hello . I replaced that wiring on my car recently ... te repair harnest for my car was . 4g0972251e
    I you have any questions just ask
  5. Re: Front brake pad sensor wiring
    Jan 2016
    Sweden
  6. Re: Front brake pad sensor wiring
    Mar 2017
    Aberdeen
    I know this thread is old but I thought it might be helpful to have my solution to the problem on the web in case anyone else searches for it in the future. My car was a 2008 B8 8K A4 but I think it's relevant here too as the wiring harness looks the same.
    I had this problem where the wires that lead to the brake sensor in the latter part of the harness were corroded when I chopped off the faulty sensor (totally black!) so twisting them together wouldn't work. I either had the option of replacing the wiring harness or finding another solution. The expense of the new harness and the faff taking off wheel arch covers and pulling the cable through, etc made me decide to do the latter. I didn't know where the cable led to inside the car so I jacked the car up so that the wheel dropped (could have removed the wheel but found that unnecessary) and then I followed the cable up to the top of the wheel arch and unclipped the two clips that were holding the cable up (pushed the clips through from the engine bay side). This released the cable which at this stage has four wires inside - two for the brake pad sensor and two for the ABS. I carefully scratched off the plastic sheath of the cable to reveal these wires. I left the yellow and red untouched (they are the ABS wires) and snipped the brown and black wires then joined together the brown and black wires together. I decided to solder but a clip would be fine. I then taped up the cable and fastened it to the engine bay again.
    Hope this helps someone else in the future.
  7. Re: Front brake pad sensor wiring
    Apr 2016
    London/UK
    23 Post(s)
    I have the same problem now
    A6 c7 2.0 2013
    Managed to unplug te abs and looked at some online diagrams too but they won't match my connector
    The diagram I was looking at its saying g that pin9 has my pads sensors , but my connector doesn't have a pin 9 cable
    What am I doing wrong here?
    EDIT: NVM, pads don't go to ABS
  8. Re: Front brake pad sensor wiring
    Mar 2025
    Lincs PE235
    For anyone who has access to VCDS and is happy to monitor their pad wear manually, as I do: The warning may be deactivated by interrogating Byte 17 in the "Coding menu" of the Central Electronics module (09). Using the "Long coding helper" the correct bit can be de-selected (set to 0) [ titled something like " Front Brake Pad Wear Sensor" ].
    I found the same symptoms.
    Wire from the Central Electronics module to the hub-mounted sensor connector at terminal no. 2 (marked on the connector under the rubber shroud) which I believe is the black wire - measured around 10v. Then when connected directly to a good Earth return via an ammeter showed a 2.5-3mA current and the warning cancelled on the next ignition recycle.
    I could not find a good path to earth from the (IIRC) brown wire in same connector at terminal 1, (Audi seem to use brown for Earth), even after flexing the loom.
    My Logic :
    I didnt locate any reliable wiring location info for the next connector inboard within the car (suspected to be in the Left kick panel), just a YouTube short showing someone shorting to earth a wire to cancel theirs on an A5 at the kickpanel connector block. None of the connector colours matched mine though. And since I had VCDS its easier to cancel the warning rather than fool the module with a messy short to earth.
    I could have spent time performing con-checks from T2 to all of the connector terminals there, simply to locate the possible neighbouring T2 return path wire, but I thought - Why bother striving to prove the fault if I'm unlikely to replace the loom, when I can simply monitor the pad wear manually.
    I may eventually replace the loom ONLY if the wheel speed sensor fails similarly, as this is needed for ABS and ESP function.
  9. Re: Front brake pad sensor wiring
    Jul 2008
    Lisburn
    16 Post(s)
    the loom in my q5 suffered from this. I got the replacment harness but it included alll the other sensors with twisted pairs... I didnt want to intrduce other issues so left it back and just replaced the pad wear section. I spliced it right back upto above the wheel in below the liner for protection, with afresh plug on th eother end. I have had no issues since. I used a heavier gauge of wire than neccessary to give it extra mechanical strength, but that did make crimping the connector on interstign lol.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  1. Where' my MAF sensor wiring?
    By Adwarrior in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-04-2017, 02:31 PM
  2. MAP sensor wiring.
    By Tom A. in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-08-2013, 09:50 PM
  3. Question Front Brake Pad Sensor
    By Jockeyblade in forum Golf MK4 - 1999 - 2004
    Last Post: 31-01-2012, 04:40 PM
  4. Airbag front crash sensor wiring!
    By noddyr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-09-2009, 03:30 PM
  5. Please Help Brake switch and brake pressure sensor issue??
    By P.M.G in forum Audi A3 - Archive Topics
    Last Post: 07-02-2009, 06:20 PM
