Thread: A3 Injector Seal Kit
Results 1 to 10 of 19
  1. Question A3 Injector Seal Kit
    Jul 2010
    Bangor, NI
    Looking for a bit of advice. I have recently bought a2 07 2.0Tdi Quattro 170, and I think there is an issue with the injector seals. The injectors were done via the recall back in 2007, but there is quite a bit of blow by when the engine is cold.Is there a kit anyone can recommend that includes everything, the seals and bolts, etc for the BMN engine ?Also any advice for doing it ?thanks
  2. Re: A3 Injector Seal Kit
    Pembrokeshire
    22 Post(s)
    what do you mean by blow by ?
  3. Re: A3 Injector Seal Kit
    Jul 2010
    Bangor, NI
    The seal on the injector is allowing gases to pass back into the crank etc
  4. Re: A3 Injector Seal Kit
    Pembrokeshire
    22 Post(s)
    so you get some puffing from the oil filler cap ?
  5. Re: A3 Injector Seal Kit
    Jul 2010
    Bangor, NI
    Exactly, a lot of pressure and smoke from under the filler cap.
    I am looking for a kit with seals and bolts to buy.
  6. Re: A3 Injector Seal Kit
    Jul 2010
    Bangor, NI
    Anyone ?
  7. Re: A3 Injector Seal Kit
    Pembrokeshire
    22 Post(s)
    its a pd engine i prersume, not common rail ?
  8. Re: A3 Injector Seal Kit
    Jul 2010
    Bangor, NI
    Yes PD
  9. Re: A3 Injector Seal Kit
    Pembrokeshire
    22 Post(s)
    then to blow combsution gas into the engine it would need to pass the bottom copper washer and the rubber o rings thats seal the feed and return pipes. i dont think the seals are your problem.
  10. Re: A3 Injector Seal Kit
    Pembrokeshire
    22 Post(s)
  1. Wanted PD Injector seal fitting tool
    By mrnice in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-10-2016, 06:55 PM
  2. 2008 q7 3.0 tdi injector seal
    By ali1 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 19-09-2016, 03:06 PM
  3. Please Help Urgent - TSI Fuel Injector Seal Kit
    By planehazza in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-04-2016, 02:03 PM
  4. Question 1.6 FSI Injector Seal Kit Part Number
    By megzdad in forum Golf MK5 - 2004 - 2009
    Last Post: 10-09-2015, 10:33 AM
  5. Please Help Touran 2.0 TDI faulty injector wiring loom and now possible injector fault
    By bigdaddysi in forum Touran - Sharan - Caravelle
    Last Post: 28-10-2013, 07:13 PM
