Thread: Audi A6 MY17 Tow Bar Retrofit
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
  1. Re: Audi A6 MY17 Tow Bar Retrofit
    #31
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    With regards to lighting, when I fitted my westaflia towbar to my 2012 a6 avant the lights didn't work until the unit had been programmed. I had side lights and brake lights on trailer board but nothing else. Once coded all worked fine for me, the indication of trailer lights is not a beep but is an additional indicator light on the binnacle.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  2. Re: Audi A6 MY17 Tow Bar Retrofit
    #32
    Dec 2007
    Nr Newport S Wales
    7 Post(s)
    Hi, I'm just about to embark on this retrofit.
    I found a swivel bar on ebay, due to land tomorrow and mow I am looking for the other bits to complete. The interface cable looks like needing to be Wibutec. That's fair enough. You said you got a genuine control module for £112. Where? Second hand are like rocking horse poo and new are £258 from a main *******. Roughly the same as wibutec.
    I do have vcds abut am a bit of a novice. If I can get it all together and working I'll put up with not having the status lights on the release lever working, but if I can get that working to then that's a bonus. Last thing I read from you last weekend was that you were missing supplies to he interface module and no trailer lights worked. What did you find there?
    Wish me luck!
    Any guidance offered gratefully received.
    Dave
  3. Re: Audi A6 MY17 Tow Bar Retrofit
    #33
    Jan 2017
    Beds
    44 Post(s)
    Quote Originally Posted by davebrannigan View Post
    Wish me luck!
    Dave
    Good luck! I gave up on mine and just use my other car with a towbar when I need to tow or throw the bike in the boot.
    I keep meaning to double check the wiring but haven't had the time.
    I've actually for a second control module for the face lift A6. I bought a 2nd one assuming it was the module that was faulty but it turned out both modules work perfectly, so it has to be a wiring issue.
    My problem was the wibutec wiring instructions didn't 100% match my cars wiring (2017 model with ACC etc). Wibutec have offered to help out via email but so far I've not had the change to pull the interior apart again to access all the wiring and control panel.
    I wish you luck!
  4. Re: Audi A6 MY17 Tow Bar Retrofit
    #34
    Dec 2007
    Nr Newport S Wales
    7 Post(s)
    Don't suppose you want to sell one of the modules then do you? ...If you can guarantee it's good... hard enough without having suspect hardware so understand why you got a second one to rule it out.
    Mines a facelift from mid 2015.
  5. Re: Audi A6 MY17 Tow Bar Retrofit
    #35
    Jan 2017
    Beds
    44 Post(s)
    Yes most likely. Audi checked both modules and they were fine. Problem must therefore be with the wiring on mine.
    Happy to sell the brand new one I got with the invoice. Not sure if it has a warranty, I'd have to check my paperwork
  6. Re: Audi A6 MY17 Tow Bar Retrofit
    #36
    Dec 2007
    Nr Newport S Wales
    7 Post(s)
    Ok well check and let me know what you find. I have two other cars with bars so no rush to get this done, but project on!
  7. Re: Audi A6 MY17 Tow Bar Retrofit
    #37
    Dec 2007
    Nr Newport S Wales
    7 Post(s)
    I now have my bar and my Wibutec harness but still haven't got a module. Have you decided whether you want to sell one of yours, and if so what do you want for it?
  8. Re: Audi A6 MY17 Tow Bar Retrofit
    #38
    Nov 2010
    birmingham
    For future before my facelift a6 was nicked i took a scan and it had swivel oe towbar Would it be possible to provide a loose guide with regards to the wiring ?
    Code:
    y,2018,16:48:41:43233
    Code:
    VCDS
    -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS
    Version: 17.8.1.0 (x64) Data version: 20171130 DS276.6
    www.Ross-Tech.com
    VIN: WAUZZZ4G5FN077867 License Plate: Chassis Type: 4G-AU57 (4G8) Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 34 36 3B 42 44 46 52 53 55 5F 62 69 6C 6D 72 85 A9 AC C0 VIN: WAUZZZ4G5FN077867 Mileage: 65516km-40709miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 22-AWD -- Status: OK 0000 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 3B-Sensor Elect. -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 85-On Board Cam. -- Status: OK 0000 A9-Struct. Borne Sound -- Status: OK 0000 AC-Reductant Control -- Status: OK 0000 C0-Act. for Ext. Noise -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CVUA) Labels: None Part No SW: 4G0 907 589 D HW: 4G0 907 589 B Component: 3.0BTD EDC17 H23 0002 Revision: 54H23--- Coding: 122A4032253603030000 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_ECM30BTD0114G0907589D 001002 ROD: EV_ECM30BTD0114G0907589D.rod VCID: 3560ACE594E997EE72-8060 1 Fault Found: 11897 - Turbocharger/Supercharger Inlet Pressure Sensor P012B 00 [032] - Implausible Signal Intermittent - Not Confirmed - Tested Since Memory Clear Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 4G0 927 158 AK HW: 0BK 927 156 AM Component: 0BK 30RTDIRdW H19 1003 Revision: --H19--- Coding: 000001 Shop #:
    WSC
    00000 000 00000
    ASAM
    Dataset: EV_TCMAL551211 002022 ROD: EV_TCMAL551211_002_AU48.rod VCID: 77FC66EDCE65A5FEA0-8022 No fault code found. ------------------------------------------------------------------------------- Address 03:
    ABS
    Brakes (J104) Labels: Redir Fail! Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q Component: ESP9 Premium H01 0420 Revision: -------- Serial number: -------------- Coding: 49B7DE4192ED7B82BB00 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_ESP9BOSCHAU57X 003019 ROD: EV_ESP9BOSCHAU57X_003.rod VCID: 3F8CCECDA6D55DBEA8-806A 1 Fault Found: 154624 - Tire Pressure Warning C102D 00 [040] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 64742 km Date: 2017.12.26 Time: 11:22:27 VzRef: 82 Bit Info 1: 00 Bit Info 2: 40 Bit Info 3: 26 Bit Info 4: 1F Uz: BA Unlearning counter according OBD: 25 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN Component: BCM2 2.0 H36 0560 Revision: 00002001 Coding: 01B9704E000000000000 Shop #:
    WSC
    02391 785 00200 VCID: 7AFA7FD9F577B896DF-802E Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C Component: J764 ELV
    MLB
    H40 0046 Serial number: 3215000030265011 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD Component: KLIMA 4 ZONEN H14 0112 Serial number: 10031500041607 Coding: 362211B82D0000 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_AirCondiComfoUDS 003008 ROD: EV_AirCondiComfoUDS_003.rod VCID: 63C422BD6AFD595EEC-8036 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: Redir Fail! Part No SW: 4H0 907 063 DG HW: 4H0 907 063 AG Component: BCM1 2.0 H20 0311 Revision: 14020001 Serial number: 00001019896102 Coding: 0105001440349FE0690140C3A0001800CF9DE7082F08020100000894E100170200400010010000 Shop #:
    WSC
    02391 785 00200 VCID: 70EE5DF1A30BF2C661-8024 Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB Component: WWS57X 150213 H37 0080 Serial number: 150218212925 Coding: 0045F7 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 23795154 Coding: 02006D Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE Component: E1 -
    LDS
    H07 0044 Serial number: 03 03 2015 00001500 Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 Serial number: F8088897000000000001 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb Part No SW: 4G0 919 475 G HW: 4H0 919 475 E Component: PARKHILFE PLA H06 0070 Revision: -------- Serial number: 56291505903880 Coding: B91318 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_EPHVA2CAU64X0000 001011 ROD: EV_EPHVA2CAU64X0000.rod VCID: 3560ACE594E997EE72-8060 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 4H0-959-655.clb Part No SW: 4H0 959 655 H HW: 4H0 959 655 H Component: Airbag10.43 H82 0086 Revision: -------- Serial number: 003P1003NJMA Coding: 30333130313730323738554A305234473053 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_AirbaAU10BPAAU64X 001014 ROD: EV_AirbaAU10BPAAU64X_AU57.rod VCID: 3B74BADDB2CD419E84-806E Crash sensor for side airbag: driver side: Serial number: 3575HRB400G52UCI4OO% Crash sensor for side airbag: front passenger side: Serial number: 3585HRB404T373K65H46 Crash sensor for side airbag: rear: driver side: Serial number: 3515JRB405T36K44K8SU Crash sensor for side airbag: rear: passenger side: Serial number: 3525JRB404V367OOPH57 Crash sensor for front airbag: driver side: Serial number: 3554VRB405H33EQGB8T7 Crash sensor for front airbag: front passenger side: Serial number: 3564VRB4010536FQQ1MO No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb Part No SW: 4H0 953 568 G HW: 4H0 953 568 G Component: Lenks.Modul H04 0005 Revision: -------- Serial number: 90372OC600093 Coding: 000035 Shop #:
    WSC
    02391 785 00200 VCID: 377CA6ED86E565FE60-8062 Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A Component: E221 - MFL H08 0009 Serial number: 20 07 2011 11153056 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb Part No SW: 4G8 920 985 L HW: 4G8 920 985 L Component: TDieGb H08 0043 Revision: 04001037 Serial number: 658100315596041 Coding: 33A612009B412600010000 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_RBD4K 004048 ROD: EV_RBD4K.rod VCID: 408ECD31DB2B2246D1-8014 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:* None Part No SW: 4G8 907 468 HW: 4G8 907 468 Component: J533--Gateway H13 0075 Revision: -------- Serial number: 00000001758281 Coding: C0CD078118 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_GatewPkoUDS 001024 ROD: EV_GatewPkoUDS_001.rod VCID: 75E06CE5D469D7EEB2-8020 Battery Monitoring Control Module: Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8041 Serial number: 6638126003 Voltage stabilizer: 1 Fault Found: 12291 - Energy Management Active U140B 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 7 Fault Frequency: 3 Reset counter: 140 Mileage: 65384 km Date: 2018.01.06 Time: 17:26:27 Voltage terminal 30: 11.5 V Voltage terminal 15: 11.4 V Control Module temperature: 8 °C System status: Terminal 15 on IN ESP_standstill flag: standstill detected Engine running: OFF IN ZAS_Te_X: On Terminal 15 status via CAN: On Terminal 15 status: On Datenfeld: 1 ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels: 4H0-907-163.clb Part No SW: 4H0 907 163 B HW: 4H0 907 163 A Component: 4 Wheel Drive H17 0200 Serial number: 002801150001042
    ASAM
    Dataset: EV_AllWheelDiffeQSPFR 003026 ROD: EV_AllWheelDiffeQSPFR.rod VCID: 285E7591535BFA06F9-807C No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb Part No SW: 4G0 919 158 R HW: 4G0 919 158 R Component: KLIMA FOND H08 0112 Serial number: 11031500040345 Coding: 22 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_ClimaContrUnitRearUDS 003004 ROD: EV_ClimaContrUnitRearUDS_003.rod VCID: 3E72B3C9A1DF54B6A3-806A 1 Fault Found: 0075 - Button or Switch in Operating Unit B10C7 07 [008] - Mechanical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 136 Mileage: 65264 km Date: 2017.12.28 Time: 17:25:49 Outside air temperature: 2.5 °C Left rear vent temperature: 41.2 °C ------------------------------------------------------------------------------- Address 34: Level Control (J197) Labels:. 4G0-907-553.clb Part No SW: 4G0 907 553 G HW: 4G0 907 553 F Component: LUFE-DAEMPFER H19 0783 Coding: 008001 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_AirSuspe 003025 ROD: EV_AirSuspe_VW51.rod VCID: 2F6C9E8D76B5AD3E38-807A 1 Fault Found: 403200 - Function Shut-Off Active C10C8 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 110 Date: 2000.00.00 Time: 00:00:00 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4G8 959 760 HW: 4G8 959 760 Component: MEM-FS H03 0157 Revision: AA000000 Serial number: 00000138980418 Coding: 0078130000006001000001010101102030303232203232 Shop #:
    WSC
    02391 785 00200 VCID: 77FC66EDC665A5FEA0-8022 No fault code found. ------------------------------------------------------------------------------- Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb Part No SW: 4G0 907 637 L HW: 4G0 907 637 G Component: SARA 6D red H04 0056 Revision: -------- Serial number: EJ1BPA7E01EMFO Shop #:
    WSC
    00000 000 00000
    ASAM
    Dataset: EV_SARA2 005012 ROD: EV_SARA2.rod VCID: 377CA6ED8EE565FE60-8062 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 4G8 959 793 J HW: 4G8 959 793 G Component: TSG FA H03 0507 Revision: -------- Serial number: -------------- Coding: 011F16015E01620002080002 Shop #:
    WSC
    02391 785 00200 VCID: 479CD62DF605157E10-8012 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb Part No SW: 4G0 909 144 S HW: 4G0 909 144 G Component: RCEPS H43 0012 Revision: 00001000 Serial number: 0021539714 Coding: 101100010001 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_RCEPS 009013 ROD: EV_RCEPS_009.rod VCID: 3978A0D5B8F1738E96-806C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN Component: BCM2 2.0 H36 0560 Revision: 00002001 Serial number: 0362785969 Coding: 013B0622A0B93094C320098420010F470000000000000000000000000000 Shop #:
    WSC
    02391 785 00200 VCID: 7AFA7FD9F577B896DF-802E Subsystem 1 - Part No: 4G0 951 177 Component: DWA-Sensor H01 0010 Subsystem 2 - Part No: 1K0 951 605 C Component:
    LIN
    BACKUP HO H05 1501 Subsystem 3 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A Component: J245 PS20.403 H03 0004 Serial number: 0000FST0006CCHB00000 Coding: 901E00 Subsystem 4 - Part No SW: 4G0 947 135 K HW: 4G0 947 135 Component: Dachelektroni H10 0100 Serial number: 0000000AP00011888356 Coding: 010000 Subsystem 5 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A Component: J394 PS20.403 H03 0004 Serial number: 0000FST0006CCNH00000 Coding: 801E00 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 4G8 959 792 J HW: 4G8 959 792 G Component: TSG BF H03 0507 Revision: -------- Serial number: -------------- Coding: 011F16015E01620002080002 Shop #:
    WSC
    02391 785 00200 VCID: 4682DB29F10F0C76EB-8012 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 H HW: 4H0 907 801 A Component: EPB-4 H04 0015 Revision: -------- Serial number: 00000001397238
    ASAM
    Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_AU57.rod VCID: 2D5084857CB9DF2E0A-8078 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb Part No SW: 4H4 907 357 E HW: 7P6 907 357 B Component: MxB-ECU 001 0100 Revision: -------- Serial number: -------------- Coding: 04FE02202A130200 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_HeadlRegulAUDIMXBAU64X 005009 ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod VCID: 346691E19F938EE645-8060 Led Headlamp Powermodule Left: Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB Component: LED LeiMo li. H07 7560 Coding: E01F00 Led Headlamp Powermodule Right: Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB Component: LED LeiMo re. H07 7560 Coding: E01F00 Matrix Headlamp Powermodule 1 Left: Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB Component: MxB LeiMo li. H03 0031 Coding: E01F00 Matrix Headlamp Powermodule 1 Right: Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB Component: MxB LeiMo re. H03 0031 Coding: E01F00 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb Part No SW: 4G1 035 021 D HW: 4G1 035 021 Component: MU-H-LND-EU 041 0389 Serial number: A588C0F7507254 Coding: 017502010000000013111102000A00132F0006E7F1700100DF Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_MUHig6C3Gen2HBAS 001115 ROD: EV_MUHig6C3Gen2HBAS_AU57.rod VCID: 1B345A5D120D219E64-804E Data medium: Subsystem 1 - Part No SW: V03 959 801 FC HW: ----------- Component: ECE 2017 --- 0157 Serial number: -------------------- Display unit 1 for multimedia system: Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A Component: DU8 C7 SV H63 0007 Serial number: AUZ8Z9EY800JEE Multimedia Operating Unit: Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F Component: E380 BDT C7 H20 0250 Serial number: 90349OBK00061 Compact Disc Database: Subsystem 4 - Part No SW: V03 959 800 EG HW: ----------- Component: Gracenote2 --- 1012 Serial number: -------------------- 1 Fault Found: 3086 - Antenna for Telephone Mount B1564 01 [009] - Electrical Failure Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 254 Reset counter: 108 Mileage: 63711 km Date: 2017.12.04 Time: 15:11:46 Voltage terminal 30: 14.5 V Status of telephone-Antenna diagnostic: OK Status of telephone-Telephone baseplate diagnostic: not connected Status of telephone-Handset in handset holder (cradle): not selected Status of telephone-Handset holder (cradle): not connected ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 4G8 959 795 J HW: 4G8 959 795 G Component: TSG HL H03 0507 Revision: -------- Serial number: -------------- Coding: 010F14004001620002080002 Shop #:
    WSC
    02391 785 00200 VCID: 4998D015E011E30E06-801C 1 Fault Found: 02123 - Door Warning Light / Entry Light 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 140 Mileage: 65384 km Time Indication: 0 Date: 2018.01.05 Time: 13:20:51 ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb Part No SW: 4G8 907 383 B HW: 4G8 907 383 B Component: Anhaenger H14 0137 Revision: 7B001001 Serial number: 0363209295 Coding: 0100000202000000 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_TrailFunctGener2Hella 001005 ROD: EV_TrailFunctGener2Hella_VW26.rod VCID: 336492FD9A9D89DE5C-8066 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb Part No SW: 4S0 907 441 B HW: 5Q0 907 441 A Component: D4-PA RVC Mid H07 0050 Coding: 027502010301000700 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_CamSysRearPANAAU914 002002 ROD: EV_CamSysRearPANAAU914.rod VCID: 326A97F9658780D657-8066 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (----) Labels:* Redir Fail! Part No SW: 4G9 959 107 C HW: 4G9 959 107 B Component: HDSG-Modul H05 0150 Revision: 14005001 Serial number: 059500647 Coding: 093205C011 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_HDSGAu572 001022 ROD: EV_HDSGAu571.rod VCID: 3662ABE989EF9CF67B-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 4G8 959 795 J HW: 4G8 959 795 G Component: TSG HR H03 0507 Revision: -------- Serial number: -------------- Coding: 010F14004001620002080002 Shop #:
    WSC
    02391 785 00200 VCID: 4998D015E011E30E06-801C No fault code found. ------------------------------------------------------------------------------- Address 85: On Board Cam. (J852) Labels:* None Part No SW: 4H0 907 217 F HW: 4H0 907 217 A Component: DPC-SG H27 0081 Revision: -------- Serial number: 262130025421000 Coding: E0140000 Shop #:
    WSC
    02391 785 00200
    ASAM
    Dataset: EV_OnBoardCamerDPC 001007 ROD: EV_OnBoardCamerDPC.rod VCID: 2C56898147A3D6261D-8078 No fault code found. ------------------------------------------------------------------------------- Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb Part No SW: 4G0 907 159 D HW: 4H0 907 159 A Component: SAS-GEN 2 H07 0007 Serial number: 150228200311
    ASAM
    Dataset: EV_SoundActuaGen2AU64X 003010 ROD: EV_SoundActuaGen2AU64X_VW26.rod VCID: 2E52838971BFA43633-807A No fault code found. ------------------------------------------------------------------------------- Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb Part No SW: 4H0 907 355 D HW: 4G0 907 355 B Component: SCR-Stg-G2 H10 0012 Revision: 00000000 Serial number: 150131144
    ASAM
    Dataset: EV_RDCMA00100 008040 ROD: EV_RDCMA00100_008.rod VCID: 2D5084857CB9DF2E0A-8078 No fault code found. ------------------------------------------------------------------------------- Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb Part No SW: 4G0 907 160 E HW: 4G0 907 160 B Component: SAS-GEN 2 AGA H09 0011 Serial number: 150302201281
    ASAM
    Dataset: EV_ActuaForExterNoiseUDS 003013 ROD: EV_ActuaForExterNoiseUDS_VW12.rod VCID: 275C76AD5E45F57EF0-8072 No fault code found. End-------------------------(Elapsed Time: 06:01)--------------------------
  9. Re: Audi A6 MY17 Tow Bar Retrofit
    #39
    Dec 2007
    Nr Newport S Wales
    7 Post(s)
    Yes I could do though if you go on a well known towbar supplier's site and select the kit for your car the instructions are right there on the side. Most of it is accurate with just a few things that could do with embellishment or clarification. That would save re-inventing the wheel.
    Before I do anything I'll take advice on whether referencing suppliers information is Ok within the forum rules. If all OK I'll write up something soon.
    Re the code dump, there are so many options that alter the coding it is impossible (for me at least) to be able to say how much of it relates to the trailer module, but Thanks anyway. I have coded mine with VCDS and got it all working with the exception of the indicator LED on the release lever and the indication on the instruments that show the bar is deployed and locked in position or stored away.
    Dave
  10. Re: Audi A6 MY17 Tow Bar Retrofit
    #40
    Mar 2014
    Ashford
    9 Post(s)
    Dave
    It’s interesting that neither of us can get the indicator led to work. It’s not the end of the world because all of the trailer lights work but I’d still love to get that status led on the handle to work one day. Please let us know if you figure it out.
  1. Q7 MY17 Rear camera retrofit
    By Q7NewBee in forum Q7 - 4M Forum - 2016 -
    Last Post: 01-07-2016, 11:03 AM
  2. MY17 Q7 Changes
    By Nemo78 in forum Q7 - 4M Forum - 2016 -
    Last Post: 08-06-2016, 09:22 AM
  3. Replies: 3
    Last Post: 15-05-2016, 01:38 PM
  4. MY17 now on UK Audi configurator
    By srbsq7 in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-05-2016, 08:37 PM
