Thread: RNS 310 Sat nav
  1. RNS 310 Sat nav
    Mar 2017
    Barry
    My VW Touran satnav has stopped working.
    It calculates the route then says the route has been calculated but then the map does not change and the route does not change
    it just show the same position on the map where it last worked ...about a month ago
    I have noticed that that the compass does ton change direction either
    any ideas?
    is there an update to install
    i have had the car almost 3 years and not had any problems
    its a VW Touran tsi 59 plate
    Cheers Dave
  2. Re: RNS 310 Sat nav
    46 Post(s)
    Sounds like a gps antenna issue, try buying a 'puck style' fakra gps antenna on eBay and seeing if it solves it.
