Thread: Slime in Air Suspension system - Audi C5 Allroad
  1. Slime in Air Suspension system - Audi C5 Allroad
    Oct 2014
    Birmingham UK
    I have had a number of issues with my air suspension which I have solved through replacement of all 4 airbags with Arnott Gen 1 bags, new valve block from Meissler Automotive and a reconditioned compressor. I hadn't realised when I embarked on all this that the system had had slime added to it sometime before my ownership 3+ years ago and this is now messing up the valve block.
    Anyway the slime is causing havoc with the valve block and I am now replacing it for the 4th time. Probably due to slime in the system. When I took the valve block off around a teaspoon worth of slime fell out the airline from the rear left pipe and I suspect there is some contamination of the rear right. This has caused the rear valves to stick.
    I have a new valve block being sent to me but before I fit I want to eradicate the slime form the system. I don't have an airline but did use a track pump for my bike to blast some shots of air down the lines and this shifted a small drop but nothing of note. I am hoping that given the system is pretty much all new thats is but advice would be appreciated.
    Any advice on how to achieve this please?
  2. Re: Slime in Air Suspension system - Audi C5 Allroad
    Ayrshire, Scotland
    18 Post(s)
    Ideally replacement of all contaminated parts to ensure the slime I out the system.
    The 4mm airhose is not expensive here:
    Metric Pneumatic Nylon 12 Flexible Tubing BS5409 & DIN 73378
    The brass airline fittings are £3 each.
    The only issue may be if slime is in the airbag, ideally changing all contaminated parts at the same time.
    Best regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  1. Audi Allroad Suspension
    By allan_audi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-05-2024, 03:31 PM
  2. audi a6 allroad suspension
    By audiestonia in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-02-2015, 08:50 AM
  3. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  4. Audi allroad air suspension ride
    By mcilwaine in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-06-2013, 10:40 PM
  5. Audi Allroad Suspension
    By gdicken in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-07-2008, 09:56 AM
