Thread: Audi A6 C5 hard to start
  1. Question Audi A6 C5 hard to start
    Feb 2017
    Norway
    Hi everyone,
    this is my first post here at this great community for Audi owners.
    I've recently bought a 1998 Audi A6 C5 2.4 AGA, and the car has some issues. I will start off with perhaps a simple one for any Audi savvy person.
    The car is hard to start, especially in the morning. Every morning I have to make 3-4 attempts before it starts.
    Even when I park the car for just ten minutes after driving, I need two attempts before it starts. Allways two. Weird.
    I've allready replaced the coolant temperature sensor, but it didn't do the trick. Still hard to start.
    I read something about that this can be the camshaft positioner sensor? Or, maybe not.
    Suggestions anyone?
    J
  2. Re: Audi A6 C5 hard to start
    There are two drain plugs in the plenum chamber the one under the battery and one directly under the brake servo. Did the oil light go out at all. ​ do not like the sound of that. Regards Peter
  3. Re: Audi A6 C5 hard to start
    Feb 2017
    Norway
    Hello Peter, thanks for answering.
    Sorry for my absence. It's been pouring down outside several days now and I don't have a garage.
    I've checked the plenum chamber and it was dry with very little dust/dirt. I suspect it was the possibility of clogged drain plugs and flooding that was your concern (?). The oil light goes out, as do the other lights.
    I failed to mention that the problem happened over night. One day it was fine, and the other day out of the blue it was suddenly hard to start.
    At that point the car did have a major oil leak that was the camshaft chain tensioner gasket on the right side, so I had the local Audi dealer change all gaskets. The mechanic told me that the spark plugs were soaked in oil, but he had cleaned them and said they were fine. I'm not entirely convinced about that.
    Does this make things a bit easier to figure out?
    J
  1. T5 2.5 TDI AXD Hard start when hot
    By zenith6225 in forum The Commercial Range
    Last Post: 24-11-2016, 09:57 PM
  2. Question Audi A3 8P 2003 - All dash lights on + hard to start
    By Simba2004 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-02-2015, 07:08 PM
  3. Solved BLB engine too hard to start... but after starting the next start is normal..
    By matrixpt in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-05-2014, 11:51 AM
  4. audi a4 tdi hard to start in morning
    By ifsot in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-01-2014, 06:18 PM
  5. Hard to start
    By daveoneill in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-03-2011, 05:24 PM
