Thread: Anyone replaced a headlight on warranty???
Results 1 to 10 of 19
  1. Anyone replaced a headlight on warranty???
    Apr 2016
    Bedford
    So I had a daytime running light die which I'm told by Audi requires a full headlight change as it's a sealed unit. Part price for headlight £798 which I don't worry too much about because the parts guy is convinced as it's a full headlight swap it'll be covered on the full electrical and mechanical warranty that came with buying the car. Anyway car goes in and warranty cover declined, I believe because the warranty dept are putting it down as a bulb which isn't covered, which is basically a cop out as far as I'm concerned. Anyone else had a headlight swap for running light out and have the same outcome regarding warranties?
  2. Re: Anyone replaced a headlight on warranty???
    Mar 2014
    Ashford
    9 Post(s)
    Ouch!
    Just out of interest, what's the age and mileage of the car?
  3. Re: Anyone replaced a headlight on warranty???
    Pembrokeshire
    22 Post(s)
    and what warranty is it ??? one you have from buying the car or one you have bought.
  4. Re: Anyone replaced a headlight on warranty???
    Oct 2016
    woking uk
    I would fight that, if you cant replace the bulb then saying bulbs arent covered by the warranty is illogical.
  5. Re: Anyone replaced a headlight on warranty???
    Pembrokeshire
    22 Post(s)
    depends how the small print is worded. if it says bulbs are not covered, then they are not covered, surely ??
  6. Re: Anyone replaced a headlight on warranty???
    Oct 2016
    woking uk
    given the limitations its the headlight that has failed, you arent replacing the bulb, you are replacing the headlight
  7. Re: Anyone replaced a headlight on warranty???
    Pembrokeshire
    22 Post(s)
    thats what it should be, but warranty companies are there to make money, not lose it, and if a bulb blown requires a new headlight, then they are probably quite glad they worded their small print so they dont have to pay out, or did they ???
  8. Re: Anyone replaced a headlight on warranty???
    Apr 2016
    Bedford
    It's a 13 plate with 35k on it and the 12 month Audi used approved warranty from when I purchased the car. Still ongoing at the moment as it's the weekend, the branch it's in with have ordered the new headlight and have requested another look at the claim to the warranty comp for me as they're in agreement that it's not actually a bulb change. Small print does say bulbs aren't covered which I can understand but I think they're using it as a get out to not cover it. I think they're classing it as item failed due to a non covered component failing. As stated by Audi when I first quieryed the need for a whole headlight change they said the daylight running light is an led strip incorporated into a sealed headlight unit so unless they're going to class the entire headlight as a bulb I think they're taking the ****. Was hoping someone might come along to confirm they'd had some success with there's. Anyway It's safe to say that if it does come back as a no again they'll be hearing quite a lot from me so will keep the thread updated.
    1 1 0
  9. Re: Anyone replaced a headlight on warranty???
    Pembrokeshire
    22 Post(s)
    totally unbelievable that anyone would be stupid enough to make a headlight where you have to replace it for a failed bulb. i wish you all the best with this claim and hope it works out in your favour. its all there though so that the car doesnt last that long, they dont want us driving about in old cars..
  10. Re: Anyone replaced a headlight on warranty???
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Getting closer to the disposable car!!!
    1 1 0
  1. Approved Warranty VS Manufactures Extended Warranty
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 14-05-2015, 08:42 PM
  2. Question Anyone got their car warranty with Warranty Direct?
    By James Clews in forum Chat - Completely Off Topic
    Last Post: 08-08-2014, 09:33 PM
  3. A4 Avant 1.9TDI Sport - Warranty or not to Warranty?
    By jackreacher in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-03-2013, 11:19 AM
  4. Chrome replaced under warranty!!
    By jimgironde in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-09-2010, 08:20 PM
  5. Wheels replaced under warranty
    By SteveX in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-05-2008, 12:44 PM
