Thread: Golf V5 2.3 20v 170bhp aqn 2001 misfire problems
Results 1 to 9 of 9
  1. Golf V5 2.3 20v 170bhp aqn 2001 misfire problems
    Feb 2011
    Mid Glamorgan, South Wales
    Hi folks i require a little help to identify a misfire in my V5 i purchased her about two weeks ago , she is totally standard not been messed with and was running nice , after a day engine light came on checked book it says emissions so i checked for obvious problems and found a split breather pipe so replaced pipe , at this point the engine is running fine with a very slight misfire at low revs but not really noticeable, I then do what i always do when i buy a car is change oil and filter and spark plugs, both were needing done oil fillter looked like it had been in there for a while very damaged , spark plugs didn't look yo pretty so i was feeling hopeful i would see an improvement in the car ..... however i now have a much worse misfire that makes her shake at low revs , i did take her out to see if it would sort its self out but the engine light came on stayed on and when i accelerate gently the light flashes indicating that it may damage the cat .... I have discovered the guilty cylinder through elimination next i would normally change leads but this where i am stuck ..... i don't know where they go as there is no coil pack and no ignition amp ?? so i am led to believe getting info on this car is difficult to say the least.
    thank you for your time reading this i hope it makes sense , Grant
  2. Re: Golf V5 2.3 20v 170bhp aqn 2001 misfire problems
    131 Post(s)
    1973 Post(s)
    Did you use the correct puller to remove the coil packs?
  3. Re: Golf V5 2.3 20v 170bhp aqn 2001 misfire problems
    Feb 2011
    Hi mate , no i didn't as i didn't realise until after the fact there was a tool ,but i do have big *** hands so i did manage to get fingers round bottom but yes i could have damaged wires hence this is where i am stuck tracking wires in looms and not knowing where they end up
  4. Re: Golf V5 2.3 20v 170bhp aqn 2001 misfire problems
    131 Post(s)
    1973 Post(s)
    You need either a fault code read to see which coil pack(s) has failed or just fit five new ones. Only fit genuine VW, almost everything else is rubbish. These coil packs often fail after removal on ALL cars with this design, it is such a common problem that we point out to customers that when we do plugs the only way we can be 99% sure you won't get a misfire in a day or so is to fit new coil packs at the same time. The missing 1% is for the odd one or two new VAG genuine coils we get which are FUBAR straight out of the box.
  5. Re: Golf V5 2.3 20v 170bhp aqn 2001 misfire problems
    Feb 2011
    ok cheers , i did swap coils and spark plugs to find problem and no matter what i swap cylinder 5 not working thus directing me to cables ?
  6. Re: Golf V5 2.3 20v 170bhp aqn 2001 misfire problems
    131 Post(s)
    1973 Post(s)
    What you should be doing is a fault code read, remember each time you take out the coils you stress them even more. We try never to remove them unless we really have to and we use a special grease on the plug ceramic to prevent stiction.
  7. Re: Golf V5 2.3 20v 170bhp aqn 2001 misfire problems
    Feb 2011
    problem solved found a broken wire .... back to full power happy days
  8. Re: Golf V5 2.3 20v 170bhp aqn 2001 misfire problems
    131 Post(s)
    1973 Post(s)
    I have a saying (well more than one), "it's never wiring......except when it is....!" You could still do with getting the codes cleared for future reference.
  9. Re: Golf V5 2.3 20v 170bhp aqn 2001 misfire problems
    Mar 2022
    Melbourne Australia
    Hi Grant,
    Can you tell me what wire was broken?
    Similar issue.
    Regards,
    Karl
  1. Please Help Audi A3 S-Line 2.0 D 170bhp Manual - Misfire, hesitation, jerks, over 3,000 rpm.
    By Shaun170D in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-06-2012, 12:55 PM
  2. Please Help 2001 mk4 golf 1.6 SE (AZD) major engine problems!!!
    By golf01 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2009, 11:10 PM
  3. 2001 Golf 1.4 16v, Engine Misfire
    By Fass in forum Golf MK4 - 1999 - 2004
    Last Post: 25-01-2009, 02:52 PM
  4. Please Help Vw Golf 1.6 16v Se 2001 Starting Problems
    By djm004 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-08-2008, 07:28 AM
  5. cyclinder 1 misfire - 2001 VW Golf 1.9 Tdi
    By soldendorp in forum Archive posts
    Last Post: 13-01-2008, 03:41 PM
