Thread: Golf R overheating - help required
Results 1 to 10 of 10
  1. Golf R overheating - help required
    Jul 2010
    Bradford, West Yorkshire
    6 Post(s)
    Hi guys,
    i have a golf R in our workshop, the customer reports that the cars temp gauge is showing overheating when driven hard.
    i have driven the car and replicated the problem, however on live data the engine temp is within in normal range. i.e goes up to around 93 then the fans kick in bringing it back down.
    a quick scan is giving two faults.
    1st it is showing the coolant level sensor has an electrical malfunction.
    2nd it is showing the coolant bypass valve to have an open circuit.
    anyone come across this sort of issue, who could point me in the right direction.
  2. Re: Golf R overheating - help required
    Jul 2007
    glasgow
    35 Post(s)
    change the coolant temp sender unit with a genuine one, what the dash says doesn't always reflect with the engine temp
    change the bypass valve as well if faulty
    that's what I would do and get the customer to come back if problem still exists
  3. Re: Golf R overheating - help required
    Jul 2010
    6 Post(s)
    Hi cheers for the reply,
    is the coolant temp sender unit different to a temp sensor?
    as the reading via live data for the temp sensor indicate it is working fine
  4. Re: Golf R overheating - help required
    Jul 2007
    glasgow
    35 Post(s)
    when you replicate the fault, what does dash say compared to live data ?
  5. Re: Golf R overheating - help required
    Jul 2010
    6 Post(s)
    Hi the dash gauge is showing between 10-15 degrees more than the temp sensor through the drive. highest the dash showed was 115 whilst the temp sensor showed 98 and then dropped down when the fans came on
  6. Re: Golf R overheating - help required
    Jul 2010
    6 Post(s)
    update-
    replaced the coolant level sensor and all is good now
  7. Re: Golf R overheating - help required
    Pembrokeshire
    22 Post(s)
    how did you get to that diagnosis ?
  8. Re: Golf R overheating - help required
    Jul 2010
    6 Post(s)
    well it was one of the fault codes showing, wiring checked out. was quite cheap to replace and customer was happy to replace.
  9. Re: Golf R overheating - help required
    Jul 2007
    glasgow
    35 Post(s)
    sometimes you have to trust the diagnostics
  10. Re: Golf R overheating - help required
    Apr 2024
    Birmingham
    Quote Originally Posted by zu11y View Post
    update-
    Hi, I got the exact same issue. I changed the coolant reservoir bottle, is that where the coolant level sensor is? or am i missing something?
    sorry to bring back to life an old thread.
  1. VW Golf 1.6 Overheating
    By AAGT150 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-09-2009, 08:31 PM
  2. Question Golf overheating
    By lumbards in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2009, 10:13 AM
  3. Question Golf Mk4 V5 overheating
    By ataylor in forum Golf MK4 - 1999 - 2004
    Last Post: 14-08-2008, 01:39 PM
  4. VW Golf MK3 overheating
    By diceyjase in forum Golf MK3 - 1993 - 1999
    Last Post: 30-07-2007, 07:21 PM
  5. Golf MK 3 GTI Overheating
    By chris goodwin in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-07-2007, 04:58 PM
