Thread: Tyre Pressures
Results 1 to 10 of 16
  1. Tyre Pressures
    Mar 2016
    11 Post(s)
    I'm curious as to what tyre pressures you folk are running with.
    I believe the recommended pressures are 38psi all round for partial loads and 33psi for comfort(?). I checked mine today and the dealer had them only on at 28psi all round.?!?!
    Keen to hear your views and experiences of ride quality at different pressures.
    I have a long trip coming up so not sure what to go with.
  2. Re: Tyre Pressures
    Mar 2010
    37 Post(s)
    228 Post(s)
    good question, i have no idea what mine are at currently.... is something in the middle the ideal? 35psi for example?
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  3. Re: Tyre Pressures
    Apr 2016
    Stansted
    169 Post(s)
    I've got the 20" 285/45 standard s-line wheels but looks like all but the 22" are the same. I go for 35psi all round and check every couple of months.
    I read elsewhere that over-inflating can increase mpg but cause uneven wear.
    My dealer missed one of the PDI checks as the tyres were all overinflated as per factory shipping standard . I think around 45psi!
    Former Q7 owner
  4. Re: Tyre Pressures
    Jun 2009
    Lowestoft, England
    10 Post(s)
    38 all round on my 21"
    Ta
    Pitch
    HIS - XC90 D5 R Design (sorry, had to be done)
    TOY - 2001 Westfield 2.1 SEW,172bhp SOLD TO MY BROTHER, I needed a PANERAI.
    HERS - 'R' New 7spd DSG and 310 rampant ones. 4.2 off the mark will do nicely
  5. Re: Tyre Pressures
    Feb 2012
    Essex
    7 Post(s)
    Just did mine at the weekend. 38 all round on my 21's.
  6. Tyre Pressures
    Apr 2016
    Stansted
    169 Post(s)
    Correct answer is 38 all round. Well, for most anyway
    I just checked what the 3 options are and it's:
    1) Partial load
    2) Partial load (comfort mode)
    3) Full load
    Checked the manual and it has a note on option 2 for when available and then a further note saying recommend option 1 or 3!
    *** - don't give 3 options if you only recommend two. I bet the f&@£wit who recommended that also worked on the train times.
    Anyway, 38 all round for me next time..
    Former Q7 owner
    0 2 0
  7. Re: Tyre Pressures
    Mar 2016
    11 Post(s)
    Yep I'm on 38 now. The whole comfort setting thing is just weird. I tried both and found no noticeable difference anyway. Settled on 38 for hopefully better mpg from now on.
  8. Re: Tyre Pressures
    Mar 2016
    Budapest, Hungary
    39 Post(s)
    Intrestingly, the US owner manual specifies for Q7 Diesel 32psi front and rear for normal load (3 persons) on 18-21 inch tire and 32psi front and 35psi rear for full load.
  9. Re: Tyre Pressures
    Apr 2016
    Stansted
    169 Post(s)
    Don't they get run-flats as standard over there? Maybe they require less pressure?
    Former Q7 owner
  10. Re: Tyre Pressures
    Mar 2016
    Budapest, Hungary
    39 Post(s)
    Maybe, but the US owner manual has a run-flat section, which does not mention a different pressure for run-flat vs. regular.
  1. Tyre pressures & Tyre wear?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-03-2010, 09:22 PM
  2. Tyre Pressures
    By traby in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-03-2010, 05:57 PM
  3. Tyre pressures and tyre pressure warning light
    By Foxtrot Oscar in forum Golf MK6 - 2009 - 2013
    Last Post: 26-07-2009, 07:14 PM
  4. what tyre pressures?
    By beaucostil in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-04-2008, 09:33 PM
  5. t5 tyre pressures ???
    By paul600rr in forum The Commercial Range
    Last Post: 22-06-2007, 04:48 PM
