Thread: help required - Q7 3.0 TDI BUG - late starting
  1. help required - Q7 3.0 TDI BUG - late starting
    Feb 2017
    PK
    Dear All,
    Frustrated and tired, i need help in diagnosing the exact problem with late starting (and sometimes never starting) of my 2007 Q7 3.0 TDI with BUG Engine.*
    On different diagnostics and advices, I*have*already*replaced the following;
    - Fuel Pump
    - Throttle Body
    - Both intake manifolds
    - Battery
    - Glow plugs
    The problem is bit funny sometimes. It would start fine when cold and rested for few days. The cranking would feel bit hard and stucky but the car would start in few seconds.*
    However, with engine mildly hot and car started again, the cranking is smooth but would go on and on and the car wouldn't start, unless when coupled with another battery and that also after a long cranking (with thick plume of white smoke, probably due to unburned diesel during long cranking). This problem is persisting from quite sometime now and has aggravated over the period of time. It has done 65K kilometers and have been kept with utmost care and timely maintenance.
    However when the car is fully hot, it would start again with ease and with a smooth cranking.
    The car is otherwise very healthy, very good engine and responses and drives like a charm. No alarms on VCDS also.
    So once gain, when the car is *
    - Very Cold - Starts fine with a hard/stucky cranking
    - Mid Hot (or when left alone after running for few hours to a day) - Wont start with very long cranking
    - Very Hot - Starts fine with smooth cranking
    Now, after recent diagnostics at dealership, i was informed of a compression loss in one of the cylinder (cyl 6 to be precise with a reading of 9 - whatever unit it is) whilst all other cylinders are showing a healthy reading of 18. Bit difficult to digest and solution is a complete over haul of upper block only (if i get lucky). Again nothing on VCDS.
    Frankly, i have lost the trust in those diagnostics and a major difficulty is that Audi in my country doesn't deals in Diesel models and this one was a personal import. So no wise mechanics with personal experience and knowledge base.
    Anybody out there with similar experience and suggestions? Please help. I have a ross tech VCDS and can run tests and provide more info if required.
    Thank you in Advance.*
  2. Re: help required - Q7 3.0 TDI BUG - late starting
    Apr 2009
    cork
    I had similar intermittent starting issues with a 2006 BUG engine, a new Starter solved it for me, fires up almost instantly.
    Might be worth getting yours checked out.
  3. Re: help required - Q7 3.0 TDI BUG - late starting
    Feb 2017
    PK
    Quote Originally Posted by joe1303l View Post
    Thankyou Joe
    Was your intermittent starting issue random (can happen in any condition) or like mine ( always starts when very cold or very hot BUT not when left for few hours to a day after driving).
    Sorry for describing it like this but I hope you would understand what I mean to say.
    Sent from my SM-G935F using Tapatalk
  4. Re: help required - Q7 3.0 TDI BUG - late starting
    Apr 2009
    cork
    Mine was definitely intermittent as it would generally but not always "struggle" to start if it had not been started for a few hours or even days.
    By "struggle", it would crank for maybe 10-20 seconds before starting, the resultant start would then give a cloud of grey smoke.
    On the times it started properly, it would start after just a few sceonds and no smoke.
    The occasions when it started properly were either when the car was started recently(less than maybe 3hrs) or totally random, outside temperature didn't make any noticeable difference.
    To clarify, it never actually failed to start but the battery often went close to going to flat. I started carrying jump leads in the boot out of fear of being stranded. The battery was replaced and even subsequently tested twice in attempt to solve the problem.
    My local Audi Dealer couldn't find anything wrong even when they kept it overnight a few timed to cold start it. As it got worse over the last 2 years, they eventually suggested either injectors or the starter.
    As injectors were €€€€, I went with replacing the starter but they were clear that they could guarantee either would fix the problem.
    It starts instantly since and I regret not having replaced the starter 2 years ago as it had really bugged me.
  5. Re: help required - Q7 3.0 TDI BUG - late starting
    Feb 2017
    PK
    thanks so much and I will go with starter motor replacement.
    Fingers crossed.
  6. Re: help required - Q7 3.0 TDI BUG - late starting
    Apr 2009
    cork
    Best of luck with it.
    FYI they allowed 4-5 hrs Labour for it from memory.
  1. Help required re cold starting problem, please
    By paultierney in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-03-2016, 12:30 PM
  2. Better to buy late model C6 or early C7 2.0 TDI?
    By mm3 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-01-2013, 09:49 PM
  3. 2.0 170 TDI DSG SEL changes up late and holds on to the revs!!!
    By Norfolk-Boy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2011, 08:24 PM
  4. Replies: 0
    Last Post: 15-12-2007, 04:37 PM
  5. Help required please ... starting problem
    By beabop in forum Chat - Completely Off Topic
    Last Post: 14-12-2006, 06:45 PM
