Thread: vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 111
  1. vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    Jun 2013
    United Kingdom
    Hi, new guy here with a question to fellow members.Just had the dreaded flashing glow plug appear on the drive home. Vcds connected and fault code shown as P0402
    EGR excessive flow.Has anyone experienced this on their VW.AUDI/SEAT/Skoda vehicle?.If so could it be resolved without trip to main agents,i have seen this on YouTube please see link Fault code P046C. ( VW golf 1.6 TDI Mk 6. 2011) EGR Valve 03L-131-512-AT - YouTube. Could anyone who has experienced the same fault share info on best way forward to resolve this issue
    best regards to all
  2. Re: vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    Jun 2013
    United Kingdom
    Hi to all, thought i would post an update ref my VCDS readings on the P0402 fault code. VW GOLF MK6 1.6 TDI CAYC 2009.When first start in the morning engine cold,i can hear the engine hunting before settling to normal 800 rpm idle.This has only occurred since this fault code appeared this.My initial thoughts are this is the air intake flaps fluctuating altering amount of airflow.Never use to hear this symptom prior to fault. Seems to disappear after approx 30 seconds when engine rps stabilizes at approx 800 rpm.On first drive no flashing glow plug light,however after approx 4-5 miles flashing glow plug appears on dash.From what i have seen on internet this points to stuck /sticking EGR valve in the EGR cooler assembly.Any help or thoughts guys would be most welcome.Looks like a difficult job to remove and de carbon this EGR valve.Especially as results are uncertain as to long term fix.Someone must have experienced this same problem i an sure.It appears all CAY-CAYC Engine owners are due to suffer from this,just a matter of time like a ticking time bomb
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZAP083446
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 B HW: 03L 906 023 A
    Component: 1,6l R4 CR td H23 8831
    Revision: --H23--- Serial number: 00000000000000
    Coding: 00114014030500080000
    Shop #: WSC 00028 028 00024
    ASAM Dataset: EV_ECM16TDI02103L906023B 003007
    ROD: EV_ECM16TDI02103L906023B_VW36.rod
    VCID: 254BEF4D24FA271
    1 Fault Found:
    7336 - EGR System
    P0402 00 [101] - Excessive Flow
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 5130 km
    Date: 2082.14.06
    Time: 16:25:39
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 133B200D092A00FDC80F04E8901F0080300000
    Shop #: WSC 00028 028 00001
    VCID: 78F5F639CBC86A9
    No fault code found.
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3C8 907 336 AB HW: 3C8 907 336 AB
    Component: Climatic H14 0305
    Revision: 00009001
    Coding: 0000000002
    ASAM Dataset: EV_Climatic A01005
    ROD: EV_Climatic_VW36.rod
    VCID: 6DDBD76DBC8ADF1
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 084 B HW: 1K0 937 084 B
    Component: BCM PQ35 B 103 0573
    Revision: 00103 AF
    Coding: 40180A3A9025180044000080300000E443010088534D816064 8000200000
    VCID: 2D5B176D740A1F1
    Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer 15100 21 0512
    Coding: 009795
    1 Fault Found:
    00061 - Footwell Lights
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 5
    Fault Frequency: 5
    Reset counter: 79
    Mileage: 58967 km
    Time Indication: 0
    Date: 2018.14.06
    Time: 16:19:06
    Freeze Frame:
    Term 15 Off
    Voltage: 12.00 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 HW: 5K0 959 655
    Component: AirbagVW10 036 0604
    Serial number: 003C2D0HC0GW
    Coding: 00003230
    Shop #: WSC 01383 790 00056
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: F7F775054ED6E51
    Crash sensor for side airbag; driver side:
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 792C504AZZZZZZZZZZZZ
    Crash sensor for side airbag; passenger side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H01 ----
    Serial number: 6553504AZZZZZZZZZZZZ
    Crash sensor for side airbag; rear driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 300F3F6EZZZZZZZZZZZZ
    Crash sensor for side airbag; rear passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3429400DZZZZZZZZZZZZ
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
    Component: J0527 053 0111
    Coding: 0000004
    VCID: 830F11D5C20EB91
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 960 N HW: 5K0 920 960 N
    Component: KOMBI H04 0308
    Coding: 470B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 387536398348AA9
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 AD HW: 1K0 907 951
    Component: J533 Gateway H07 0111
    Revision: H07 01 Serial number: 211009F1000901
    Coding: E9801F06000202000001
    VCID: 69D3A37D4062C31
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0308
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EAD15C710D64489
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
    Component: Tuer-SG 009 2122
    Coding: 0000628
    VCID: 336F0115522E491
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 69 3001
    Revision: 00H17000
    VCID: 31630B1DA8327B1
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
    Coding: 0000628
    VCID: 346D020957204E9
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 G HW: 3C8 035 195 G
    Component: Radio RCD510 050 0207
    Revision: 00000001 Serial number: VWZ1Z3M7089804
    Coding: 01000400040005
    VCID: 2C5D1A694F10169
    End ------------
  3. Re: vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    131 Post(s)
    1973 Post(s)
    Just fit a new valve, cleaning them doesn't work. I have tried an aftermarket unit as an experiment and OK so far after a few months but until I am happy I still prefer genuine because of the 2 year labour inclusive warranty. These units are such a sod to fit that it makes life simpler but then again I have not had a replacement fail yet and we have been doing a lot of these over the last three years. The worst one is the A1 and the Polo, there is so little space around the unit it takes twice as long as a Golf 6.
  4. Re: vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    Jun 2013
    United Kingdom
    Hi Crasher, thank you for your kind reply to my question,i will take it that i am on the right track then with this assumption its the EGR flow valve causing this fault code P0402?
    Have followed many of your answers and suggestions to other members problems,so i respect your knowledgeable/professional opinion.Am i correct in assuming this job will take approx 4-6 hours for a technician, at a garage with all the equipment car lift etc.Also is the cost likely to be approx £800 using as you suggest only genuine VW parts.I am now 59 years of age lifetime on spanners,but not automotive industry.Don't fancy prospect of trying this removal/refitting process laid on my back with car on axle stands.Possible maybe but bloody difficult even if this allows access room
  5. Re: vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    131 Post(s)
    1973 Post(s)
    Quote Originally Posted by jumpjetguy View Post
    Assumption is a dangerous thing, I say "always check" but it has got to the point that if I get anything with a CAYC engine come in with the MIL on, I almost don't bother to code read them now, it's nearly always the EGR valve. You need 03L 131 512 DQ plus you may need heat shield 03L 131 531 A if one isn't fitted and a pile of gaskets/fasteners.
  6. Re: vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    VAG Error Code:
    16786/07336/01026
    EOBD II Error Code: P0402
    Fault Location:
    Exhaust Gas Recirculation (EGR) System - Excessive Flow Detected
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Reduced Exhaust Gas Recirculation (EGR).
    Reduced Power Output/Engine running rough.
    Increased Emissions.
    Wiring/Connector(s).
    Exhaust Gas Recirculation (EGR) Valve stuck open/leaking/faulty.
    Exhaust Gas Recirculation (EGR) System leaking/faulty.
    Possible Solutions:
    Check/Replace all faulty Wiring/Connector(s).
    Check/Clean Exhaust Gas Recirculation (EGR) System.
    Read Measuring Value Blocks (MVB).
    Check/Replace Exhaust Gas Recirculation (EGR) Valve.
    When is the code detected?:
    High Exhaust Gas Recirculation (EGR) flow control is detected.
    VAG Error Code: 00061
    Fault Location:
    Footwell Lights - Electrical Fault in Circuit/Open Circuit/Short Circuit to Positive
    Possible Cause:
    Fuse(s).
    Failed or incorrect bulb installed.
    Possible Solutions:
    Check/Replace Fuse(s).
    Check correct bulbs are installed.
    As taken from my new EOBD II Error Codes
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  7. Re: vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    Jun 2013
    United Kingdom
    Hi Kieth, thank you for your most kind input ref my current fault code problems.I am thinking that the solution to the foot well lights might be as you point out wrong bulb type fitted.I have retro fitted two front foot well lights,however these have LED type bulbs incorporated inside.The rest of my Golf mk6 1.6 tdi CAYC 2009 interior courtesy lights are all the old incandescent bulb type.So maybe a mismatch on the can bus system throwing this error code.No warning light on dash for this error however,only showing on VCDS scan.Other possibility is i used incorrect long coding for this retro upgrade.Please may i ask do you have any info on what the coding change should have been,for this mod on my three door Golf.However this is all small potatoes when viewed against my EGR fault code ref P0402 excessive EGR flow.Looking like i will have to bite the bitter pill and have this changed professionally at a reputable garage.Would be up for changing this myself even at 59 years of age,however experience tells me this is not the kind of job for a garage floor operation.With the car on axle stands not much access provided too low.Even when this has been replaced and fault cleared hopefully,the prospect of this reappearing in another 36,000 fills me with dread and not a little anger!!!
    Such a blight on this VW engine model CAY - CAYC. Have read on internet forums VW owners are paying between £800-£1000 to have this item repaired by replacement.Wish i had known this when i bought the car new,would probably have opted for a petrol model.hindsight is a wonderful thing
  8. Re: vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    Jun 2013
    United Kingdom
    Hi Crasher, thank you for the up date info and pic,mine is slightly different to your pic but not splitting hairs.My 2009 did not have the extra heat shield fitted that you mention,must have been brought in later. VW certainly never fitted it on their annual service for the first three year either the only update they did was a ECU software update. Would all be so easy if engine looked like this on a pallet,piece of cake to change bags of access.Oh well dream on i assume this is a pic of the later heat shield you mention not fitted on my 2009 model s-l1600 (100).jpgEGR cooler assy cayc.jpgEGR cooler assy 2.jpgegr heat shield new addition.JPGs-l1600 (41l).jpg
  9. Re: vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    131 Post(s)
    1973 Post(s)
    If you don't have the heat shield, ETKA says to fit it with the new unit.
  10. Re: vw golf mk6 1.6 tdi cayc engine P0402 FAULT CODE
    Jun 2013
    United Kingdom
    Thank you Crasher, i will be sure to do as ETKA directs and fit the retro mod heat shield to the vacuum actuator on the EGR cooler assy.
    Strange it came with one fitted on the turbo vacuum actuator,but not down below in close proximity to EGR exhaust pipework.Maybe they had instances of the heat degrading the vacuum actuator diaphragm or abs plastic body. Love the pic of the old Vulcan,i saw it flying on its farewell tour close to Warton Lancashire.When i first went on the spanners as an apprentice this is what i worked on, the good old English Electric Canberra circa 1977.Will get under the car later today and vacuum check the EGR cooler actuator.However i think the most people suffer fault codes, related to the Electric operated type Sickle valve.Which acts against the open close plunger type valve on the EGR.Screenshot (191).jpgScreenshot (192).jpgScreenshot (193).jpg
  1. CAYC 1.6 tdi diesel engine. Unresolved EGR problem.
    By nickbell1uk in forum Golf MK6 - 2009 - 2013
    Last Post: 10-10-2017, 04:55 PM
  2. Golf 1.6 Bluemotion CAYC Engine EGR Replacement guide
    By dave254 in forum Golf MK6 - 2009 - 2013
    Last Post: 23-11-2015, 05:06 PM
  3. fault code p2563 on mk6 1.6 tdi bluemotion golf .
    By grantjohne in forum Golf MK6 - 2009 - 2013
    Last Post: 25-01-2014, 06:18 PM
  4. Replies: 5
    Last Post: 28-03-2012, 10:27 AM
  5. Emissions Workshop. Fault code p0402
    By tyro in forum Golf MK4 - 1999 - 2004
    Last Post: 20-07-2010, 10:25 PM
