Thread: a6 c6 2.0 tdi fuel problem
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: a6 c6 2.0 tdi fuel problem
    Jan 2016
    coventry england
    thank you zollaf for replying , am i right in thinking that if 1 injector goes the others will follow?
  2. Re: a6 c6 2.0 tdi fuel problem
    Pembrokeshire
    22 Post(s)
    oh aye, yes. but, could also be a blocked fuel filter or water in the fuel. the filter needs changing regardless, so why not try it first.
  3. Re: a6 c6 2.0 tdi fuel problem
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    This sounds spookily like what happened to my 2005 2.0TDi. It drove normally, then lost power when trying to accelerate. I'd back off the throttle and try again and it would be fine. Then it would happen again - and I noticed HUGE clouds of black smoke behind the car. No faults were logged, and the dealer it got recovered to was stumped. They replaced lots of parts (MAF, ECU, fuel filter, tank, fuel lines) and still the car did it. Finally they figured out it was the EGR valve - the flap had become detached from the spindle inside the valve, so the flap was sticking in the open position even though the sensor saw the spindle was in the closed position (hence no faults logged). A new EGR valve later and all was good. Might be worth getting the EGR valve checked?
    Good luck!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
    2 1 0
  4. Re: a6 c6 2.0 tdi fuel problem
    Jan 2016
    coventry england
    thanks for your thoughts MF, had a call from the audi specialists and they say the timing is out by 2 notches and this needs to be sorted before they can go any further, basically they are doing a cambelt and pump change first and take it from there! i knew the belt needed doing but was saving it for the summer shutdown but the mechanic is "talking the talk" and knows what he"s on about compared to the previous garage! so sometime early next week i"m going to get one hefty bill!
    1 1 0
  5. Re: a6 c6 2.0 tdi fuel problem
    Jan 2016
    coventry england
    update for anyone interested, the garage replaced the injectors and have now found that the problem stemmed from a blocked dpf which didnt show up on the dash as a fault because when it was remapped they turned the lamp off.(dont really know the right words for this) anyhow the filter blocked so the gases blew the turbo and the injectors too. so as it stands its cost me £2400 and still no guarantee that it will solve the problem!! thanks again to all who offered advice on the problem.. to be continued
    1 1 0
  6. Re: a6 c6 2.0 tdi fuel problem
    Jan 2016
    coventry england
    final update, so after 10 weeks i finally got the car back today 15/3/17, in exchange i had to hand over £3680, so basically it had most of the fuel/exhaust systems replaced, . turbo and harness,egr valve, dpf cleaned out (blocked solid) tandem fuel pump, 4 injectors,the alledged remapped ecu reset to factory condition, drives just the same as when it was supposed to have been mapped.oil feed line,crank seal and pick up ring, crank sensor,fuel filters and bolts etc,looking at the bill, i have done pretty well on the labour side, so the car isnt perfect but its running . the dpf light still doesnt light up when the ignition is switched on, i assume its supposed too, but i dont care at the moment,once the novelty of having it back has worn off i will look into it.
    so a warning to all those thinking of having a remap, make sure if the dpf is deleted make sure the insides have been removed !!!!. final thought, i now believe the car was remapped by the previous owner and the mobile bloke knew it and got a easy £180 off me,the mapper has disappeared off the planet, no answers to calls or email and the facebook profile has also gone, so next time i will use a garage, if there is a next time!!!
    thanks to all who responded to my plea for help and i hope my experience helps out someone else and avoid the expense!!!
    1 2 0
  7. Re: a6 c6 2.0 tdi fuel problem
    #17
    Aberdeen
    63 Post(s)
    Glad you got it sorted. Expensive lesson though. Fingers crossed for several trouble free years of motoring!
  8. Re: a6 c6 2.0 tdi fuel problem
    #18
    Jan 2016
    coventry england
    thanks Scott, forgot to add to the bill £200 at the original garage who didnt have a clue plus extra insurance for borrowing my lads car, could of gone to florida for that lol.
    still not perfect when cold but its running, would be lost without sites like this one and the internet, and for all the trouble its caused i still love the car!!!
  1. 1.4 TDi 90, poor fuel economy problem
    By Cloth Ears in forum A2
    Last Post: 17-09-2012, 12:01 PM
  2. A6 TDI fuel problem
    By thornton66 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-06-2009, 05:56 PM
  3. 02 passat SE TDI fuel problem
    By 1964johnr in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2009, 10:41 AM
  4. 1.9 TDI Fuel Gauge Problem
    By paul b in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-01-2009, 10:37 PM
  5. golf gt tdi 130 fuel problem
    By tuffrey_105 in forum VCDS - General Questions
    Last Post: 26-05-2008, 01:22 PM
