Thread: Vw Polo 2010 TDI EGR valve
  1. Vw Polo 2010 TDI EGR valve
    Jan 2017
    uk
    Hi All
    first posting
    I have a Vw Polo TDI 2010 with 68000 miles .
    the car keeps showing the yellow coil light i believe this is to do with the egr valve the car goes into limp mode.
    i switch the ignition off it clears for a while but comes back on.My garage state its the EGR valve needs replacing and its a long job and will cost £700
    is this right .
    can i add a product called JML into the tank to clear this or am i wasting my time?
    also has anyone done this job at home DIY and could offer me advice how they did this
    thanks in advance
    Ned
  2. Re: Vw Polo 2010 TDI EGR valve
    Jul 2007
    glasgow
    35 Post(s)
    the yellow coil light just means you have a problem, of which there could be a thousand problems
    if the garage has scanned the car & that is the fault, then you can shop around OR go to another garage and ask to see the fault on their scanner & get another quote to supply and fit an egr valve
    you could go to an indy VW garage in your area for a quote
    you could also go to VW for a genuine egr from the Parts department, sometimes a genuine part doesn't cost any more than and it should last
  3. Re: Vw Polo 2010 TDI EGR valve
    Dec 2014
    Bedford
    42 Post(s)
    The egr is about 329 plus vat plus the gaskets from vw.
    Sent from my SM-G900F using Tapatalk
  4. Re: Vw Polo 2010 TDI EGR valve
    Jul 2007
    glasgow
    35 Post(s)
    That's some price eh ? My Audi A6 was £130 from Audi !!!
    Can you take to another garage to read the code for the fault ?
    Diesel cars need an Italian decoke around once a month, put car in 2nd gear, boot it for a few hundred yards and hold the revs just under the red and watch all the rubbish getting blasted out the exhaust in your mirror
    this will restore power & mpg
  5. Re: Vw Polo 2010 TDI EGR valve
    Dec 2014
    Bedford
    42 Post(s)
    Not worth the bother cleaning these egr valves . It's way to hard to get to and they are as reliable as a pensioner's erection.
  1. Please Help Egr valve 038131501t on mk4 gt tdi 1.9 130pd ..broken part of valve body
    By Dobbo37 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-09-2013, 07:13 PM
  2. 1.9 tdi EGR Valve
    By sam.bird3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-06-2013, 04:05 PM
  3. egr valve location polo 2001 1.0e
    By yas_b in forum Polo - Derby - Lupo - Fox
    Last Post: 27-02-2010, 10:03 PM
  4. 2.5 tdi egr valve
    By quattrogary in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-12-2009, 04:03 PM
  5. 03 1.4 16v Polo EGR valve.
    By endofreak in forum Polo - Derby - Lupo - Fox
    Last Post: 01-09-2009, 01:33 PM
