Thread: A8 2005 Air Suspension Gremlins
  1. A8 2005 Air Suspension Gremlins
    Mar 2009
    Cheshire
    My Air suspension on my A8 2005 3.0tdi has been acting a little strange over the last few weeks.
    Firstly it may not be related but on three separate occasions (after driving the car fairly hard) at the end of the journey there was a loud noise , sounds a bit like a drill see this link noise - YouTube
    The noise occurs even after the engine has been switched off. It lasted around 20 mins and nearly drained the battery. The noise comes from the area where the air compressor is located (front nearside just next to the wheel well)
    Subsequently on various occasions over the last few weeks, the amber air suspension light has illuminated intermittently. Each time I have run diagnostics with VCDS and no error codes have been reported.
    I am at a loss to understand what is going on here. If anyone can offer any suggestions or share similar experiences I would appreciate it.
    UPDATE:
    Amber light came on again today so ran VCDS and now reports the following errors:
    Address 34: Level Control Labels: 4E0-910-553.lbl
    Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
    Component: LUFTFDR.-CDC H06 4480
    Coding: 0015520
    Shop #: WSC 01130 210 66681
    VCID: 2855E0E09B0DDA5EFC3-807D
    3 Faults Found:
    01400 - Suspension Level Control
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 229
    Mileage: 176800 km
    Time Indication: 0
    Date: 2016.12.28
    Time: 08:49:16
    01772 - Signal from Level Control Pressure Sensor (G291)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 31
    Reset counter: 229
    Mileage: 176805 km
    Time Indication: 0
    Date: 2016.12.28
    Time: 15:28:48
    01583 - Leak in System Detected
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 8
    Reset counter: 228
    Mileage: 176876 km
    Time Indication: 0
    Date: 2016.12.30
    Time: 18:30:34
    So looks like I have a leak somewhere? Can anyone suggest a good Air Suspension specialist in the Cheshire area?
  2. Re: A8 2005 Air Suspension Gremlins
    Aberdeen
    63 Post(s)
    Can't help with a specialist but if you search the A6 C5 forum, a lot of the guys on there have had similar problems and have rebuilt compressors and fitted the bags themselves. They can probably give you some pointers.
  3. Re: A8 2005 Air Suspension Gremlins
    Dec 2007
    I think I read that the relay on the compressor can be shot in most cases too. I would look at that first.
  1. Air suspension air valve removal
    By Shab2015 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 02-04-2018, 08:59 PM
  2. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  3. 1.9 tdi rear suspension gremlins!!
    By ian k in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-09-2012, 10:29 PM
  4. A6 - more fuel guage, air condition gremlins
    By noproblem in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-07-2010, 09:00 AM
  5. A3 Sportback poss suspension prob 2005 2.0 tdi
    By davelympany in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-06-2007, 05:50 PM
