Thread: VW Passat yr 2005, 2.0 FSI B6 (3c) Radiator Fans Running at Max
  1. Unhappy VW Passat yr 2005, 2.0 FSI B6 (3c) Radiator Fans Running at Max
    Jan 2017
    Nairobi Kenya
    Dear all, I have a VW passat sport yr 2005, 2.0 FSI engine, engine code BLR.
    The Radiator fans start running at max the moment the car starts, i have changed the temperature sensor below the radiator but nothing changes, when diagnosed i get the errors
    P1290 Coolant temperature sensor at radiator outlet signal too high
    P1672 Radiator Fan actuation1 open Circuit/earth short
    Initially i thought the problem was the fans, I installed a new set still the problem persists any help will be appreciated thanks
  2. Re: VW Passat yr 2005, 2.0 FSI B6 (3c) Radiator Fans Running at Max
    Apr 2007
    France
    12 Post(s)
    Have you read the thread at the bottom of the page?
    Question 2005 1.6 FSI - Cooling Fans and Temperature Sensor Problem
    might be helpful.
    1996 Laguna 2.2D
    1977 MGB roadster
  1. 2005 A6 3.2l FSI - Belt tensioner changed now running lumpy.
    By Bertros in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-08-2017, 11:58 AM
  2. Question 2005 1.6 FSI - Cooling Fans and Temperature Sensor Problem
    By Peter OJ in forum Golf MK5 - 2004 - 2009
    Last Post: 13-06-2016, 02:02 PM
  3. Please Help Both radiator fans running while parked up and switched off
    By energize in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-10-2012, 10:40 PM
  4. Question Passat B6 radiator fans - which is which?
    By DickBrowne in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-07-2012, 08:02 AM
  5. Question Radiator fans
    By v6mikey in forum Golf MK4 - 1999 - 2004
    Last Post: 10-07-2009, 05:42 PM
