Thread: Squeal when turning steering wheel
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Squeal when turning steering wheel
    Nov 2016
    england
    33 Post(s)
    Hi i have a slight squealing noise when turning my steering wheel and there's another noise too (will let you know which when I hear it again) it's not all the time but It is often obviously I'm worried because it's my steering and i will be expecting to be driving distances over the Christmas, can anyone help with this???
  2. Re: Squeal when turning steering wheel
    Jul 2013
    76 Post(s)
    Check the power steering fluid level and do not use normal ATF fluid.
    Check the cap for the fluid type its most likely G00200 A2
    look at this post.
    Power Steering oil change
    I found that TPS are doing it for £8.07 a Bottle at the moment.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Squeal when turning steering wheel
    Pembrokeshire
    22 Post(s)
    which engine. ?? check the one way pulley on the alternator. does the tensioner bounce about a lot ?
  4. Re: Squeal when turning steering wheel
    Nov 2016
    england
    33 Post(s)
    Ok thank you though my last power steering fluid to be put in was done with fluid supplied by an independent German car garage (i had a power steering pipe leaking that then burst) could they have used the wrong fluid? I've had the noise for a while but they are the ones that have done everything on it since I bought it though i didn't notice the noise when i bought the car, oh and what's tps?
  5. Re: Squeal when turning steering wheel
    Nov 2016
    england
    33 Post(s)
    3.0 tdi, i would have to check the pulley another day, sorry i don't have a garage, also sorry it's actually more of a squeak
  6. Re: Squeal when turning steering wheel
    Jul 2007
    glasgow
    35 Post(s)
    there could be a very small leak, but check the power steering level first
    the most important thing is check the Cap and see if it says either MINERAL or Hydraulic
    Do Not Mix
  7. Re: Squeal when turning steering wheel
    Nov 2016
    england
    33 Post(s)
    Quote Originally Posted by niall campbell View Post
    Do Not Mix
    Even after having the burst pipe repaired? Though admittedly they patched it instead of changing it as the higher cost of replacing it(this was done twice as the hose the first garage used wasn't good enough according to the second garage)will check the level and the type required tomorrow and post what I find about that thank you
  8. Re: Squeal when turning steering wheel
    Jul 2007
    glasgow
    35 Post(s)
    you could take off the pipe and go to an agricultural engineer and get a hose made up, if a new one is really expensive
    any connection can leak if not tightened up properly, or new seals fitted, nuts cross threading etc
    My A6 needed topped up due the age of the mineral oil in mine at 10 year old, no leak thankfully; mineral oil breaks down over time
    I can only say that " the muckabout factor" is different to every person, and having been at a 2nd garage ................................ then maybe a proper hose isn't that expensive an option ............... google hydraulic pipe repairs and get a quote
  9. Re: Squeal when turning steering wheel
    Nov 2016
    england
    33 Post(s)
    Nah it was fitting it that was the expensive side due to access not being good (i was told by the first garage that the pipe goes behind the engine so it would possibly be an engine out job, I don't know if this is right due to me not having a manual of any kind and no experience with audis or a v6) so the garage made the decision (and the second garage just did a better job of what the first garage did) though having spoken to people with more experience of power steering problems than me they said that a patched pipe shouldn't be a problem and that they have usually been fine for them
  10. Re: Squeal when turning steering wheel
    Nov 2016
    england
    33 Post(s)
    And obviously after the burst pipe all the fluid was put in fresh
  1. Noise when turning the steering wheel
    By takksi in forum Golf MK6 - 2009 - 2013
    Last Post: 29-09-2014, 01:01 PM
  2. Noise when turning steering wheel
    By Bazaar in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-04-2014, 10:49 AM
  3. Please Help Squeal/ Squeak from front wheel on turning
    By barnsy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2013, 05:14 PM
  4. Knocking when turning steering wheel!
    By Simpsvag in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-08-2009, 08:24 PM
  5. Question Squeeking when turning the steering wheel
    By maxtothemax in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-05-2009, 04:24 PM
