Thread: Best way to glue Audi rings badge on?
  1. Best way to glue Audi rings badge on?
    Jul 2012
    Shropshire
    Hi guys.
    Ages ago my rear Audi rings badge fell off the boot of my car when someone was pushing me for a bump start I've finally got around to getting a new badge from my local dealer. Here's the issue - they told me to simply wash off the grey residue that is still on my boot and simply peel back the plastic on my new badge and put it on firmly but I am not confident that this will work.
    The reason for this lack of confidence is that there is a little part of the sticky already peeled back and it is hardly sticky at all. The other question I have is is the advice correct regarding cleaning off the old residue? And if so, what would you guys recommend?
  2. Re: Best way to glue Audi rings badge on?
    46 Post(s)
    The badge is self adhesive, ensure the surface is clean and dry.
  3. Re: Best way to glue Audi rings badge on?
    Jul 2012
    Shropshire
    Thank you. The Audi garage suggested using a hair dryer to get the residue off the boot. Any advantage to putting the new badge on when it's still warm as opposed to how cold it is right now?
  4. Re: Best way to glue Audi rings badge on?
    Aberdeen
    63 Post(s)
    Make sure the area is very clean. Wash with fairy liquid or similar to strip off any wax / polish that may be present. Rinse and dry very well before applying the decals. You can also use glue / tar remover to help remove the sticky residue. This is available from detailing shops etc.
  5. Re: Best way to glue Audi rings badge on?
    Pembrokeshire
    22 Post(s)
    a wipe with brake cleaner should remove the tack and ensure the surface is squeeky clean ready for the new badge.
  6. Re: Best way to glue Audi rings badge on?
    Jan 2010
    southport
    Zippo type lighter petrol is good for removing glue.
    2000 2.5TDI Quattro 173,000miles, just run in...Sold
    2006 TT 3.2 Quattro 40,000miles
    2005 A6 Avant 3.0TDI Quattro
  7. Re: Best way to glue Audi rings badge on?
    Feb 2017
    Yorkshire
    Had success using Loctite glue remover. This product is not pricey also.
  1. A4 B8 front Audi rings
    By dode in forum Body Work, Body Styling and Body Kits
    Last Post: 05-01-2014, 09:34 PM
  2. 4 rings grille badge part number
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2012, 04:50 PM
  3. New generation audi q5 rings the changes
    Last Post: 07-05-2012, 07:18 PM
  4. Please Help 2006 A4 Avant grille badge (Audi rings)
    By Fingers66 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-10-2010, 11:34 PM
  5. Question Black Audi Rings
    By 2.0TDISline in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-08-2010, 05:21 PM
