Thread: What's under the carpet in a 1996 A4?
Results 1 to 10 of 10
  1. What's under the carpet in a 1996 A4?
    Mar 2016
    Minervois, France
    54 Post(s)
    Yesterday I took my wife to the local hospital in pouring rain, and parked up in the car park.
    Her appointment was for 4 pm but we didn't get to leave until nearly 6 pm.
    While we there there was a huge downpour with howling wind which we could even hear inside the building.
    When we finally got back to the car my wife asked why the passenger window was open - it was all the way down.
    I must have accidentally pressed the passenger window switch on the driver's door when I was getting out. When you lock the driver's door (no remote locking), the front windows wind back up if they are open - but only if you hold the key in the lock position for a couple of seconds, which I obviously had not done.
    The dashboard was completely covered in rainwater, the oddments trays and other hollows on the centre console were full to overflowing, and there was a huge amount of water on the seats and the floor. I was amazed that everything electric seemed to work, and drove back with my a*se on the soaking wet seat, still in really heavy rain.
    Today, thank the Lord, it was sunny, if quite cold (for here, about 16º), so parked the car in the driveway and mopped the seats and floor as best we could with kitchen paper, and let the sun and breeze into the car for as long as it lasted.
    The carpet, apart from the removable mats in the front, does not come out easily, and I don't fancy removing it as it probably won't go back nicely. There is every possible thing, including the front seats, fixed over it, but it is just starting to feel a bit less damp on the surface.
    So I'm wondering - what is under ithe carpet? Is there any chance it will dry out underneath at this time of year without taking it all up? And if it doesn't how long will it take to rust through the floor?
    I'm toying with the idea of driving over to Morocco to dry it out in the Sahara.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  2. Re: What's under the carpet in a 1996 A4?
    Dec 2014
    Bedford
    42 Post(s)
    Sound deadening is under the carpet. It really can hold a lot of water in the sound deadening. If you have ac turn it on and this will remove the moisture and run around with it on for a few weeks. Or get under the car you will find grommets in the floor pan take some out and it will work it's way out. As for rust very unlikely.
    Sent from my SM-G900F using Tapatalk
  3. Re: What's under the carpet in a 1996 A4?
    130 Post(s)
    1972 Post(s)
    Normally about 18 gallons.....
    1 1 0
  4. Re: What's under the carpet in a 1996 A4?
    Oct 2016
    Blackpool
    Like has been said, the sound deadening stuff can hold a hell of a lot of water, I have had a similar experience. You can't squeeze it out, it doesn't drain. Best way I got rid of the water in the sound deadening material was to lift the carpet and get a cheap fan heater from b and q, set the heater off pointing under the carpet. Took a full day pretty much to dry it it, but it does work. Take care with position of the heater so it doesn't overheat.
    Sent from my E5823 using Tapatalk
  5. Re: What's under the carpet in a 1996 A4?
    Mar 2016
    Minervois, France
    54 Post(s)
    I have been parking the car in the sun with all the doors wide open and it is certainly a lot less damp, just hoping I can get away with it I suppose.
    What is the electric nestbox for, at the front of the picture please?
  6. Re: What's under the carpet in a 1996 A4?
    Dec 2014
    Bedford
    42 Post(s)
    Convenience control unit. Door locks electric windows mirrors etc.
  7. Re: What's under the carpet in a 1996 A4?
    Mar 2016
    Minervois, France
    54 Post(s)
    The control unit with pump for my door locking, interior light delay, etc. is in the RH side of the luggage compartment. Convenience unit is not in the list of component locations in my Bentley manual.
  8. Re: What's under the carpet in a 1996 A4?
    130 Post(s)
    1972 Post(s)
    Quote Originally Posted by FrenchAudi View Post
    that is because yours is very early, the incompetence unit moved from the right rear corner where it used to overheat and moved under the left front carpet where it became the incontinence unit...
    1 1 0
  9. Re: What's under the carpet in a 1996 A4?
    Mar 2016
    Minervois, France
    54 Post(s)
    That's a small relief, thanks.
    Maybe I'll take it out of its strange foam insulated packet to keep it cooler. It can't be difficult to make a better support for it than an elastic band.
    If that's progress I'm glad I only have old cars
  10. Re: What's under the carpet in a 1996 A4?
    Oct 2005
    Before you put everything back together again, park nose down on an incline to ensure all the water is brought into the front footwell(s).
  1. carpet
    By dieselbundy@aol in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2010, 05:20 PM
  2. Please Help carpet
    By passat tdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-04-2010, 10:12 AM
  3. carpet
    By peagreenpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-10-2009, 07:50 PM
  4. A6 Carpet
    By markgrff17 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-02-2009, 09:21 PM
  5. Starting problems - Audi A6 in 1996 VOLVO 850 TDI CD 1997 (Manuf 1996)
    By Grandad Dave in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2008, 10:42 AM
