Thread: Exhaust Tips
Results 1 to 10 of 10
  1. Exhaust Tips
    Apr 2013
    Stirling
    11 Post(s)
    Hi all... Was wondering if anybody has changed their exhaust tips!? I'm looking into doing just that but noticed a couple of weld spots annoyingly to keep them in place! The oem ones are around 90mm. And back box outlet will be around 85mm. So my question to anyone that has done this did you cut the original ones off or just use something to break the welds with a grinder or just brute force?
    Sent from my SM-G935F using Tapatalk
  2. Re: Exhaust Tips
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by AlyM View Post
    Hi Aly,
    My pre-facelift (albeit a 2.0 TDi with twin pipes on the left) had what appear to be the same finishers. On my car they were a push-fit. There were metal tangs inside which gripped onto the outside of the underlying exhaust pipe. A firm twist-and-pull action (wearing rubber gloves for extra purchase) was all that was needed to remove them. When they were off the car, there were a couple of dimples visible which could easily have been mistaken as weld spots if they were dirty...
    Hoping yours are the same as mine were!
    Edit: If you look at the image on this ebay page, you can see the metal tangs inside which hold them on. Might take some effort to remove them if they have been on there for a while, but you should be able to do it
    http://www.ebay.com/itm/Audi-A6-4F-o...ht_2766wt_1105
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
    1 1 0
  3. Re: Exhaust Tips
    Apr 2013
    Stirling
    11 Post(s)
    Quote Originally Posted by MFGF View Post
    Hi Aly,
    Cheers!
    MF.
    Hi Mark.. Thanks for the info! I had another look and unfortunately it's definitely welded on..
    You can see the spot weld on the inside also..
    And underneath
    The link is that not for a C6 as it says 4F?
  4. Re: Exhaust Tips
    Feb 2014
    Leicestershire
    19 Post(s)
    Hi Aly,
    MF.
    My B8 A4 2.0 tdi was exactly like this, I yanked off the manky ones and replaced them with eBay ones.
    The C7 A6 is definitely more of a job!
    If you do manage to get them off then a how to PLEASE!
  5. Re: Exhaust Tips
    Aug 2013
    18 Post(s)
    If you’re replacing them because of the condition then try this first… it’s very, very good
    Autosol Solvol Chrome Metal Aluminium Cleaner & Polish The Original & Best | eBay
  6. Re: Exhaust Tips
    Apr 2013
    Stirling
    11 Post(s)
    Quote Originally Posted by fest0r View Post
    Fancied replacing them with Carbon fibre tips...
  7. Re: Exhaust Tips
    May 2009
    69 Post(s)
    And underneath
    Hi Aly,
    The link was just for illustration. The tips on my 2.0 C7 looked the same as those, and just pulled off. Looks like yours are different, sadly. Here's the best pic I have of the ones on that C7 (after the big rear-end shunt it got):
    Cheers!
    MF.
  8. Exhaust Tips
    Mar 2016
    Leeds UK
    I just got mine sliced off with a saw and got some new ones welded on
    1 1 0
  9. Re: Exhaust Tips
    Apr 2013
    Stirling
    11 Post(s)
    Quote Originally Posted by Saan View Post
    Nice one Saan... Looks 😍
  10. Re: Exhaust Tips
    Nov 2016
    Surrey
    looks good, need to my A7 ones as they are looking pretty nasty
  1. Exhaust tips
    By dan2485 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-02-2014, 04:14 PM
  2. A4 tdi standard exhaust tips cut and replaced with s4 or twin tips help
    By Ruairi83 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-12-2013, 07:37 PM
  3. Question Exhaust Tips ??
    By A4 Lad in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-03-2011, 09:07 PM
  4. Question Exhaust tips...
    By benjie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-11-2009, 08:38 PM
  5. Exhaust tips
    Last Post: 19-09-2009, 10:54 AM
