Thread: Audi A4 B8 2009 Drivers door not unlocking via remote?
  1. Audi A4 B8 2009 Drivers door not unlocking via remote?
    Apr 2016
    Manchester / United Kingdom
    Hello lads,
    Got an problem and hope to find solution here, ive had the car for about 6 months+ now, and about 2-3 weeks ago the drivers door didnt unlock anymore, recently only with key manually i can get it open. When i drive and lock (like going shopping) and come back within 30mins, then usually opens via remote, but if longer then does not. only via key.
    Audi wants £60 just to diagnose the problem, i read something about sticking microswitch ect? ...
  2. Re: Audi A4 B8 2009 Drivers door not unlocking via remote?
    Aug 2014
    Slovenia
    Do other doors lock/unlock fine? How is your lock function set? One press unlocks only drivers door or all doors?
    AUDI A4 B8 2.0TDI 2010 100kW CAGB
  3. Re: Audi A4 B8 2009 Drivers door not unlocking via remote?
    Apr 2016
    Ive tryed both settings, all doors and just drivers door.
    Other doors and boot open fine no issues.
  4. Re: Audi A4 B8 2009 Drivers door not unlocking via remote?
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by WorldUK View Post
    Common issue with door lock, first try some oil or dw40 to the keyhole and play with fob, if no luck, time to replace or at least try to clean contacts(maybe you got lucky).
    No lock beep since replacing power lock actuator!?!?!!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  5. Re: Audi A4 B8 2009 Drivers door not unlocking via remote?
    Aug 2014
    Slovenia
    Since all doors unlock fine i would assume that problem is not electric related. If you have vcds you can check driver door status for switches.
  6. Re: Audi A4 B8 2009 Drivers door not unlocking via remote?
    May 2016
    Dublin
    Hi!
    I read your thread and realised that I had the exact same problem as you had. As such, I wrote a guide to do the repair in case it could help yourself or anyone else with a similar problem. Repairing Audi A4 B8 8K door not unlocking with remote fob
  1. Replies: 2
    Last Post: 26-12-2016, 07:27 PM
  2. drivers door not unlocking with fob (other doors do though...)
    By shuggy1001 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-08-2016, 03:57 PM
  3. Drivers side door not unlocking
    By Perplexed in forum Golf MK5 - 2004 - 2009
    Last Post: 04-11-2015, 07:58 PM
  4. Please Help Drivers door not unlocking properly
    By Sadly Clueless in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-12-2014, 03:01 PM
  5. 2002 TDi drivers door remote unlocking problem
    By m0pdq in forum Golf MK4 - 1999 - 2004
    Last Post: 22-04-2008, 10:08 PM
