Thread: Audi A4 Cabriolet - Roof warning light flashing 10x
Results 1 to 10 of 11
  1. Audi A4 Cabriolet - Roof warning light flashing 10x
    Nov 2016
    Salisbury, UK
    Hi guys, I'm new here, and just bought my Audi, expect my welcome post soon
    I have a 2006 A4 3.2 FSI Quattro S-line. - B7.
    Anyway, the roof works perfectly. But when I turn the engine on I get 10 flashes of the warning light.
    Had the faults read
    02000 - Switch position inplausible
    01986 - Convertible top frame position sensor (G356) - electrical fault in circuit
    00532 - Supply voltage B+ lower limit exceeded
    (top frame poition for G356 was 237)
    I had them reset, put the roof on and off a few times, no light at all.
    Drove for week or two (perhaps 5-7 roof cycles) - all OK
    Now come back on again!
    I've looked at the top frame position sensor (on one side at least - are there two?) and it looks to be plugged in and hasn't broken. The whole system looks pretty tidy.
    Seems silly buying a sensor if it's not that.
    've only used roof with engine on.
    Any ideas?
    Thx
  2. Re: Audi A4 Cabriolet - Roof warning light flashing 10x
    Nov 2016
    Salisbury, UK
    Streamlining posts
  3. Re: Audi A4 Cabriolet - Roof warning light flashing 10x
    Nov 2016
    Salisbury, UK
    bump
  4. Re: Audi A4 Cabriolet - Roof warning light flashing 10x
    Oct 2005
    Have the codes also returned?
  5. Re: Audi A4 Cabriolet - Roof warning light flashing 10x
    Nov 2016
    Salisbury, UK
    That was my next step - to find that out. I'd imagine a code has returned, and I'm assuming the same, but need to check that out.
  6. Re: Audi A4 Cabriolet - Roof warning light flashing 10x
    Oct 2005
    There's a manual roof reset procedure which may clear the warning light, but I suspect there's something else amiss.
    Reset procedure is detailed in this thread; How do you reset automatic roof?
  7. Re: Audi A4 Cabriolet - Roof warning light flashing 10x
    Nov 2016
    Salisbury, UK
    Yeah, I saw that, but thoiught it's stramge having to manually wind it when the roof actually works. Could be worth a pop I guess.
    I did reset the light, but it came back.
    I'll try a manual reset and read the codes again I guess. It's just weird getting an error when it all works.
  8. Re: Audi A4 Cabriolet - Roof warning light flashing 10x
    Nov 2016
    Salisbury, UK
    Quote Originally Posted by Sam View Post
    Hello mate, just had it read/reset with VCDS, and the codes were as follows:
    02000 - Switch position - 008 - implausible signal - intermittent
    01986 - Convertible top frame position sensor (G356) - 012 electrical fault in circuit
    01988 - Convertible top operation switch (E137); Close 012 - electrical fault in circuit - intermittent
    The roof works fine - not done manual reset yet.
    Any ideas?
  9. Re: Audi A4 Cabriolet - Roof warning light flashing 10x
    Nov 2016
    Salisbury, UK
    Edit - manually reset roof - fingers crossed
  10. Re: Audi A4 Cabriolet - Roof warning light flashing 10x
    Nov 2016
    Salisbury, UK
    Warning light back , but took a few cycles to do so
    getting this
    But sensor looks OK?
    Time to replace it?
  1. Audi A4 Roof Flashing Light
    By Chris McCann in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-09-2013, 09:49 AM
  2. Please Help 2003 A4 3.0 Cabriolet - shaking and engine warning light flashing!
    By craig79 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2013, 08:53 AM
  3. A3 Cabrio roof warning light flashing on start up
    By vb2111 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 17-05-2012, 01:21 PM
  4. Cabriolet roof warning light
    By Gary H in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-01-2009, 11:28 AM
  5. hood warning light flashing 10x on startup
    By a4audio in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2008, 01:34 PM
