Thread: VCDS draining the battery? A6 C6 3.0 TDI
Results 1 to 10 of 14
  1. Unhappy VCDS draining the battery? A6 C6 3.0 TDI
    Oct 2016
    Croatia
    Hi guys,
    really sorry that my first post is a problem post, but that's the way the cookie crumbles.
    My story is:
    Bought an A6 3.0 TDI avant a month ago, a sweet runner, 220 000 km on the clock, nothing wrong with her at all. Decided I'd really like to have the green service menu active and tinker a bit with the coding and the rest, so I bought a VAG COM kit off emanuals.com. It arrived today and since then, my life hasn't been the same. Before you ask, the cable seems legit, it says Ross Tech 12-12.
    Unpacked the cable, installed the recommended version 12.12.3 and connected it to the car.
    Got round to activating the green menu, did that all ok, went into the coding for the "07-Control Head" as I wanted to change the welcome screen logo, and then all went south. All of the screens in the car died. Pressed cancel in VCDS, switched off the ignition, plugged out the cable. Put the key back into the ignition, but the MMI screen was very slow to turn on. Now the really strange thing: as I would turn the ignition off, the MMI would turn ON! After a few back and forth's with the key, I decided I'd try and start the car, but it was giving all the signs of a dead battery. Strange, given that by that point I'd spent 3 minutes max with the ignition on.
    Did a full scan and the only things reported were under voltage errors for most components. Cleared everything, but the error 00003 - Control Module 005 No or Incorrect Basic Setting / Adaptation was persistent. Not really sure how I managed to clear it as it wouldn't have it for a good while.
    Things got back to normal by clearing all the errors, but even after 3 hours of charging the battery, the car wouldn't start, even tho the battery level indicator was at say 60%. Managed to start the car by jump starting it off a mate's Sprinter. It started 3 times since that, but I'm kind of worried about tomorrow morning... Has the battery fried itself? It was perfectly normal all this time and indicator always had it at 100%.
    My question is: how did I manage to **** this up so badly? Has anyone else had this? I'd like to tinker some more in VCDS but I'm afraid of touching the thing after the unfortunate debut!
  2. Re: VCDS draining the battery? A6 C6 3.0 TDI
    46 Post(s)
    You're using a non genuine, Chinese clone cable.
    If you didn't pay over £200 for the cable, 99% it'll be a clone.
    These below are the only authorised resellers for RT.
    Gendan Limited
    Unit 14 Llys Caer Felin
    Felinfach
    Swansea SA5 4HH
    +44 0 1792 588002
    ilexa Onboard Diagnostics
    Truro, Cornwall TR2 4YF
    p: +44 01726 884 010
    f: +44 01726 808 021
    Sub-Distrib:
    NHN
    Sales@vagcom.biz
    Uckfield
    East Sussex
    p: +44 07974 994 143
    Marshall's Industrial Ltd.
    Volkswagen Power Systems & Components
    IMPCO Gas Systems
    Beadle Estate
    Hithercroft Road, Wallingford,
    Oxfordshire, UK
    OX10 9DG
    p: +44 (0) 1491 834666
    f: +44 (0) 1491 839777
    email: sales@mi-uk.com
    V-Tech UK Ltd.
    SN Autohaus,
    181, Forest Road,
    Hainault, Essex
    London, UK
    IG6 3HZ.
    Tel: +44 208 498 1288
    Fax: +44 208 498 1289
  3. Re: VCDS draining the battery? A6 C6 3.0 TDI
    Dec 2014
    Bedford
    42 Post(s)
    Lol
    Sent from my SM-G900F using Tapatalk
  4. Re: VCDS draining the battery? A6 C6 3.0 TDI
    Jul 2013
    76 Post(s)
    Chris,he is in croatia
    Dan
    2009/2010 2.0 TDIe SE
  5. Re: VCDS draining the battery? A6 C6 3.0 TDI
    Oct 2016
    Croatia
    Thanks for the reply Chris, in fact the 60 quid seemed way too cheap. It will have great use as a slingshot. Hopefully nothing's wrong with the car!
  6. Re: VCDS draining the battery? A6 C6 3.0 TDI
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by FLAPPERJACK76 View Post
    Lol
    Where is here funny part?
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  7. Re: VCDS draining the battery? A6 C6 3.0 TDI
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by Crash_meere View Post
    Check the log files(debug), you may find out what went wrong!
  8. Re: VCDS draining the battery? A6 C6 3.0 TDI
    Oct 2016
    Croatia
    Small update, the car started fine in the morning, drove to work no problem. Started it after work do drive to my in-laws place (3 k away from work), got there no problem, but wouldn't start later. Getting the same symptoms of a flat battery (very slow cranking), but the battery indicator in the MMI says 80%. Didn't have a voltmeter on hand at the time (it was dark already, and pretty cold (3 deg C). I'll try to get a reading tomorrow. Time for a new battery or a new voltage regulator? I understand it's a big ole donk under the hood and cranking it over requires a lot of juice, especially in the cold. Any chance it could be a faulty regulator from the VCDS tinkering?
  9. Re: VCDS draining the battery? A6 C6 3.0 TDI
    Oct 2016
    Croatia
    Quote Originally Posted by Gunnark100 View Post
    I'd love to, but I'm afraid of hooking it up. Call me a wuss, but Audi parts and service aren't cheep in my neck of the woods.
  10. Re: VCDS draining the battery? A6 C6 3.0 TDI
    Oct 2012
    Estonia
    64 Post(s)
    There is no need to hook up vcds, in your computer, where is vcds folder, there must be "debug" folder, in there is adaption and coding log, where you see what you changed etc...
    All those things with vcds are usualy "operator" error or your battery was so f... dead that battery manager shut everything off !
    But nearly dead battery with battery manager can cause all kind of issues! Many c6 3.0tdi in my tiny country had starter and ground problems over the years, its hard to diagnose! I dont belive its voltage regulator!
  1. Please Help 2.0 draining battery
    By volvofh in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 18-01-2011, 08:27 PM
  2. Please Help Stereo draining battery Audi A4 1.9 Tdi 2002
    By RG32 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-10-2010, 07:11 PM
  3. Battery Always draining
    By dod530d in forum TT - 8N Forum - 1998 - 2006
    Last Post: 11-12-2009, 10:58 PM
  4. draining battery
    By coyotee in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-09-2009, 04:54 PM
  5. Please Help Battery draining
    By medman in forum Golf MK3 - 1993 - 1999
    Last Post: 23-06-2009, 09:57 AM
