Thread: How to siphon fuel from 2.5 TDI V6?
Results 1 to 9 of 9
  1. How to siphon fuel from 2.5 TDI V6?
    Jul 2009
    Birmingham
    My A6 V6 TDI is dead but has 3/4 of a tank of diesel in it. How would I go about siphoning the fuel out so I can re-use it?
    Down the filler neck is a no-no as it has an anti-tamper device.
    Is it possible to connect an in-line pump to the fuel filter and suck it out from there? Or is there a better method?
    Don't really want to mess with the under-seat pump if I can avoid it as I would like to sell the car as intact as possible for spares/repairs (and currently does start).
    Thanks,
    Chris
  2. Re: How to siphon fuel from 2.5 TDI V6?
    Oct 2016
    preston lancs
    the only way i know how is the under seat in tank pump way, it's not that hard o remove and refit them, also i bought a cheap fuel pump with positive and negative posts and use 2 bits of hose at each end then run some wire from the car battery to the pump and just drop the end in tank, there may be a way of disconnecting the fuel lines under the car before it reaches any electrical pumps but i'm not savvy on the A6
  3. Re: How to siphon fuel from 2.5 TDI V6?
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    In Allroad C5 TDI a clear flexible plastic tube 12 mm diameter 2.2m Length Do the job, 1.1 meters go into the tank The rest comes to the ground. A small Sucking and empty container. After that get the most Under the back seat left side of the vehicle Has a easy access You can get into the fuel tank to remove the rest
  4. Re: How to siphon fuel from 2.5 TDI V6?
    Jul 2009
    Birmingham
    Quote Originally Posted by amiram View Post
    Don't these vehicles have a little filter down the filler tube, which stops siphoning?
    Chris
  5. Re: How to siphon fuel from 2.5 TDI V6?
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    Quote Originally Posted by reddevil View Post
    Chris
    I did this several times in my car and it is written in the work shop manual this is for a quattro. for a non quattro See photos attached. A=495mm
  6. Re: How to siphon fuel from 2.5 TDI V6?
    Jul 2009
    Birmingham
    Am I right in thinking if the tank is 3/4 full, opening the pump in the back seat will result in a bunch of diesel in the passenger compartment?
    I am not sure what a=495mm is referring to, or what the photo is telling me. Sorry to be dense.
  7. Re: How to siphon fuel from 2.5 TDI V6?
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    Before you open the pump Open the fuel filler cap Insert through the fuel filler Clear plastic Flexible pipe D= 10-20 mm, Half a meter or more length, The other end of the pipe must reach the ground and Sucked the fuel
  8. Re: How to siphon fuel from 2.5 TDI V6?
    Jul 2009
    Birmingham
    Thanks - stuck some hosepipe down there tonight and indeed you can get to the fuel. Ordered a syphon pump from Amazon to get it going, as don't fancy getting a mouth full of fuel...
    How much should I be able to get from the tank before I need to access the pump?
    Chris
  9. Re: How to siphon fuel from 2.5 TDI V6?
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    much as you can
  1. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  2. Replies: 0
    Last Post: 10-12-2013, 04:47 AM
  3. Question What is the best way to prime a 2.0 tdi fuel system after changing fuel filter?
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-10-2012, 09:40 PM
  4. Question B8 3.0 tdi Vs B7 3.0 tdi Fuel Consumption.
    By Burfy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-08-2012, 12:06 AM
  5. fuel consumption on 3.0 tdi 204PS v's 2.0 tdi 170PS??
    By ac606 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-12-2008, 08:35 PM
