Thread: engine turns over but doesnt start P0321 engine speed sensor input circuit incorrect signal.
Results 1 to 8 of 8
  1. engine turns over but doesnt start P0321 engine speed sensor input circuit incorrect signal.
    Ive a Passat B6 2007 2.0D (196k MILES) and the engine has just died: Vag says "p0321 engine speed sensor input circuit incorrect signal"
    haynes says "the engine speed sensor is mounted on the frontleft hand side of the cylinder block, adjacent to the mating surface of the block and transmission housing."
    Ive been lead astray by haynes recently (you dont need to remove the rear calipers to replace the rear disks.) Can anyone help with a more exact location perhaps with a picture?
    VAG ALSO SAYS "DTC: P1266,Valve for pumpinjection, cylinder 3; imlausibles signal" Frankly that looks expensive so I thought I would look at the engine speed sensor first.
    any guidance warmly received.
  2. Re: engine turns over but doesnt start P0321 engine speed sensor input circuit incorrect signal.
    Norfolk
    Speed sensor error will not stop car starting. Engine has camshaft and crankshaft sensors. Either will start the engine. A failed injector will prevent engine start. That is your main fault.
  3. Re: engine turns over but doesnt start P0321 engine speed sensor input circuit incorrect signal.
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    There's a wiring fault somewhere in the injector loom (no 3 cylinder) as the engine speed sensor is a common red herring thrown up by loom faults. Or as Martin1810 states the injector itself is at fault and unfortunately will be expensive.
    Mad Mitch
  4. Re: engine turns over but doesnt start P0321 engine speed sensor input circuit incorrect signal.
    Thanks Guys, I cleared the error codes and they have not reoccurred. It feels like a fuel starvation problem. Currently workin on that: the Fuel filter barrel is not full and not filling on turnover although theres a definite suction. My guess is fuel tank filter, I think there is a fuel tank lift pump but I would have thought a malfunction would have created a fault code.
  5. Re: engine turns over but doesnt start P0321 engine speed sensor input circuit incorrect signal.
    Sep 2008
    SE London
    TDi fuel pump filter block doesn't create its own error code -- only red herrings if that
    Tapping its side may dislodge sludge build up from the sides of the fuel filter, but only to have it return
    Complete pump has to be replaced as internal filter a non-changeable item by itself
  6. Re: engine turns over but doesnt start P0321 engine speed sensor input circuit incorrect signal.
    So it did turn out to be the electric fuel pump in the fuel tank. An easy fix for £100. The engine sings as sweetly as before. I guess the moral of the story is: use the error codes for guidance but use your brain and experience too.
    Thanks for all your help.
  7. Re: engine turns over but doesnt start P0321 engine speed sensor input circuit incorrect signal.
    Jan 2012
    10 Post(s)
    88 Post(s)
    Great result - on the error code subject I have found that not all error codes are genuine and relate to the problem encountered. It's as if in rarer cases the ECU when it is not able to make sense of the signals received throws a guess at another component on the car. The crank speed sensor often seems to be one of the default red herrings depending on the nature of the actual problem.
    Mad Mitch
  8. Re: engine turns over but doesnt start P0321 engine speed sensor input circuit incorrect signal.
    Norfolk
    The error codes from the ECU are set by very precise logic (no guesswork). It is up to humans to interpret the codes. Sometimes we can, sometimes we can't.
  1. Engine coolant sensor circuit high
    By grahamjf in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2016, 10:51 AM
  2. Audi A4 2.0 TDI BPW Cab - G28 Engine Speed Sensor Implausible Signal
    By brasiliangringo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-11-2015, 11:19 PM
  3. Replies: 0
    Last Post: 09-01-2014, 11:17 AM
  4. Replies: 3
    Last Post: 10-05-2012, 04:14 AM
  5. starter turns but engine won't start
    By ser17 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-02-2008, 06:35 PM
