Thread: Tiguan propshaft carrier bearing renewal??
  1. Tiguan propshaft carrier bearing renewal??
    Oct 2016
    bangor
    Hi all
    I'm a newbee to the forum and in need of some assistance if anybody can help.
    I have a 2008 Tiguan 4 motion. The propshaft carrier centre bearing has gone and I have purchased a retro fit bearing instead of the the complete new propshaft. I am stuck with two things. The front of the propshaft came away easy enough but not the rear section. I have removed the three bolts but it does not want to budge. I tried then to do the retro fit with the aft section still in place but I cant see how to remove the CV joint, which is on the splines. I was expecting a circlip to be holding it in place but I cant see one. I have used a bearing puller incase its just a press fit but only a slight amount of movement.
    Where am i going wrong. I think if i can get the cv joint off then I could continue doing the repair in situ but it would all be sooo much easier if I could get the propshaft to the bench.
    Very gratefull for any assistance.
    vinndy
  2. Re: Tiguan propshaft carrier bearing renewal??
    Oct 2016
    bangor
    Just an update to this. I finally got the aft section off. I used a load binder to pull it off and that worked fine. I put the section in the vice and used a hub/bearing puller to pull the star of the cv joint off. This turned out to be just a press fit with no circlip. There was a copper ring in a grove near the end. Not sure how they got that in place as it looked like a closed ring to me. As well as the puller I also used a bit of heat and some gentle tapping. One it started to move then the puller did the rest.
    Fitting of the new bearing carrier went OK once I found a suitably sized drift to tap it home.
    The most difficult/awkward job was refitting the ballbearings in the cv joint. I got it in the end but coulnt describe how I did it. probably more by luck than chance.
    I marked up the two sections and realigned them to those marks. I'm still not convinced that it is necessary to align them back up the same way when there is a wearable bearing in the middle. I would have thought that as long as each section is balanced then it should be OK. I took no chances though and the car drives well with no vibration.
    This repair has saved me £1500 which is scandalous when the replacement bearing only cost £100. A lot of scaremongering by VW in saying that it cant be done without special equipment and then the risk of it being out of balance.
    vinndy
  3. Re: Tiguan propshaft carrier bearing renewal??
    Dec 2023
    Orkney
    Quote Originally Posted by vinndy View Post
    Thanks for sharing vinndy.
    I believe they can assemble this incorrectly, I'm having the same problems you seem to be having.
    I believe you are meant to hammer the bearing race down until the copper ring reveals itself, then remove the ring then use a puller to remove the race. However, mind will not hammer down, I wonder if it has been installed upside down and if I should just apply a larger puller or if I am going to destroy it horrifically.
    I'm actually debating buying a new prop for £400ish, for all the hassle and the delay I'm not feeling the love for this parts design at the moment.
    What would you advice be?
  4. Re: Tiguan propshaft carrier bearing renewal??
    131 Post(s)
    1973 Post(s)
    What is the VIN as from a quick look a genuine exchange recon “Cardan shaft” as VAG call it is £1400 + VAT?
  1. Audi A4 B6 2.5tdi quattro propshaft centre bearing
    By JaptechSmokey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-04-2015, 04:48 PM
  2. Propshaft 'clunk'.
    By M3 Compact in forum A8 - S8 - V8
    Last Post: 26-01-2015, 03:20 PM
  3. propshaft driveshaft
    By davey thomas in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2012, 01:46 AM
  4. Quattro propshaft centre bearing
    By gjm123 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-01-2011, 12:25 PM
  5. Question A3 Torque settings/wheel bearing renewal
    By kicky in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-10-2009, 11:29 AM
