Thread: Long Life service scedule interval
Results 11 to 20 of 22
  1. Re: Long Life service scedule interval
    Coventry
    Quote Originally Posted by a8 tech View Post
    Mark 5 golf long life is 9000 minimum 19000 maximum or 24 months.This is based on pr number qg1 and nobody messing with adaption channels ie not checked at pdi or previous owner on time and distance regime.
    How can longlife servicing be justified if the mileage they specify will be attained within a year. wouldn't annual be better?
    TBH i was looking forward to seeing service in 18 - 19K appearing on the dash.
  2. Re: Long Life service scedule interval
    Coventry
    VAG are rapidly dropping the Long Life interval and so should you unless you want to pay for a new engine. I have seen a ridiculous number of cars on Long Life lose oil pressure.
    then why have longlife?
  3. Re: Long Life service scedule interval
    130 Post(s)
    1972 Post(s)
    Do you mean from VW's or the customers perspective?
  4. Re: Long Life service scedule interval
    Coventry
    either.
    why have a long life service interval when its no longer than the annual service interval.
  5. Re: Long Life service scedule interval
    130 Post(s)
    1972 Post(s)
    From VW's perspective it sounds good when selling the car, mainly from a fleet perspective and the customer thinks they will have to spend less on serving with less inconvenience. The interval for Longlife is two years/20K miles. The system does benefit fleets as they can buy a new car, run it for two years, sell it and not service it.
  6. Re: Long Life service scedule interval
    Coventry
    this is what i thought. so why is mine due again in 14600? i do more than 7300 in a year.
  7. Re: Long Life service scedule interval
    #17
    130 Post(s)
    1972 Post(s)
    The dash has been reset to standard; probably the mechanic did the reset on the panel, not via the diagnostic computer.
  8. Re: Long Life service scedule interval
    #18
    Coventry
    i'll give them a ring i think.
  9. Re: Long Life service scedule interval
    #19
    May 2007
    knee deep in clunge
    14 Post(s)
    VW Golf (1K) Instrument Cluster
    From Ross-Tech Wiki
    Jump to: navigation, search
    Contents [hide]
    1 Coding
    2 Security Access
    3 Adaptation
    3.1 Channel 002: Service Reminder
    3.2 Channe 003: Consumption Correction
    3.3 Channel 004: Language
    3.4 Channel 009: Mileage/Odometer
    3.5 Channel 022: Production Mode
    3.6 Channel 030: Fuel Gauge Adaptation
    3.7 Channel 035: Speed Threshold
    3.8 Channel 038: Oil Minimum Detection
    3.9 Channel 039: Oil Level Sensor Adaptation
    3.10 Channel 040: Mileage since Service
    3.11 Channel 041: Time since Service
    3.12 Channel 042: Minimum Distance to Service
    3.13 Channel 043: Maximum Distance to Service
    3.14 Channel 044: Maximum Time to Service
    3.15 Channel 045: Oil Quality
    3.16 Channel 046: Total Consumption
    3.17 Channel 047: Soot Entry
    3.18 Channel 048: Thermal Load
    3.19 Channel 049: Minimum Time to Service
    Coding
    00??x0x: Options
    +01 = Brake Pad Warning
    +02 = Seatbelt Warning
    +04 = Washer Fluid Warning
    +16 = Sedan (only VW Jetta)
    00xx?0x: Country
    1 = Europe (EU)
    2 = USA (US)
    3 = Canada (CDN)
    4 = Great Britain (GB)
    5 = Japan (JP)
    6 = Saudi Arabia (SA)
    7 = Australia (AUS)
    00xxx0?: Distance Impulse Number
    1 = 22188
    2 = 22076
    3 = 21960
    4 = 21848
    5 = 22304
    6 = 22420
    7 = 22532
    Security Access
    13861 = Adaptation Enabling
    Adaptation
    0 = Service NOT Due
    1 = Service Due
    To reset the service reminder save 0 as new value.
    Standard Value: 100 %
    Display Range: 85...115 %
    Increments: 1 %
    New Adaptation Value = Old Adaptation Value * Calculated Consumption / Old Display Value
    1 = German
    2 = English
    3 = French
    4 = Italian
    5 = Spanish
    6 = Portuguese
    7 = No Text
    8 = Czech
    Increments: 1 = 10 km or 1 = 10 mi
    The distance can only be changed once before the current value is not over 100 km/62 mi. After changing the value can be corrected within the next 5 km/3 mi of driving.
    Standard: 100
    Range: 120...136
    Increments: 1 Ohm
    This value represents the speed threshold of the dynamic oil pressure system. The threshold can be raised in increments of 250 RPM.
    With this function the oil-minimum-warning at low oil level can be deactivated or activated.
    Determines if the TOG Sensor is installed or not.
    Increments: 1 = 100 km
    Increments: 1 = 1 day(s)
    Increments: 1 = 1000 km
    365 = fixed Service Intervals (w/o Longlife)
    730 = flexible Service Intervals (with Longlife)
    1 = fixed Service Intervals (w/o Longlife)
    2 = flexible Service Intervals (with Longlife)
    Retrieved from "http://wiki.ross-tech.com/index.php/VW_Golf_%281K%29_Instrument_Cluster"ViewsArticle Discussion View source History Personal toolsLog in / create account Categories
    Main Page
    Fault Codes
    Diagnostic Procedures
    Vehicle Appl. Charts
    DLC Locations
    FAQ
    Search
    Toolbox
    What links here
    Related changes
    Special pages
    Printable version
    Permanent link
    This page was last modified 19:49, 27 February 2007. This page has been accessed 6,277 times. Privacy policy About Ross-Tech Wiki Disclaimers .If you can get the dealer to check you adaption channels you will be ble to calculate what has gone wrong,if they appear ok check channel 48 as this can indicate incorrect oil type which monks thee settings up as the quality is poor and the oil level sensor calculates a lower than expected duration as does channel46 and 47 also.
  10. Re: Long Life service scedule interval
    #20
    Coventry
    rang them.
    it seems that the car is capeable of adjusting the service counter by its self.
    so if you were to thrash the car everywhere then you would reduce the interval likewise with lots of short journeys, however, do motorway mileage and the car may increase the interval.
    Its all down to the way its driven.
  1. Am I on long life servicing?
    By dubourg in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-04-2008, 01:06 AM
  2. Black Long Life 3 oil
    By pk00213 in forum Archive posts
    Last Post: 19-09-2007, 06:39 PM
  3. Long Life Service
    By bora(ing) nick in forum Bora - 1998 - 2005
    Last Post: 12-09-2007, 10:38 PM
  4. Long-Life Oil Top Up Question
    By JRPdark in forum Passat - Archive Topics
    Last Post: 18-07-2007, 09:18 PM
  5. Long Life service
    By bora(ing) nick in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-01-2007, 03:33 PM
