Thread: Brake Fluid and Coolant Flush
Results 1 to 10 of 14
  1. Brake Fluid and Coolant Flush
    Sep 2012
    Romford, UK
    Hi, I have bought my 2006 Audi A6 in 2012 and haven't replaced Brake fluid or Coolant since then. I have no problems at the moment, but considering getting them replaced. Can you please suggest if the below products and the quantity will work for my A6 2.0 TDI 2006. Thanks.
    Comma BF4ESP1L DOT 4 ESP Synthetic Brake Fluid (or) Pentosin Super Dot 4/ Plus (or) Pentosin Dot 4 LV (or) ATE TYP200 (or) ATE SL6 -- 1L
    Genuine Audi G13 Coolant, Part No. G013A8JM1 -- 4X1.5L
  2. Re: Brake Fluid and Coolant Flush
    Nov 2012
    Somerset UK
    I had mine done at Halfords for a total of £58 inc, and their longlife coolant meets Audi spec.
  3. Re: Brake Fluid and Coolant Flush
    Sep 2012
    Romford, UK
    Hi Mark, Thanks for your reply. I have a garage who regularly does my service. I usually supply the parts. I would like to stick with them rather than going to Halfords.
  4. Re: Brake Fluid and Coolant Flush
    Jul 2013
    76 Post(s)
    Look at the coolant bottle for the G code as you car should be G12 or G12+ there is a colour difference.
    TRIPLE QX Red (Concentrate) Antifreeze/Coolant 1Ltr
    Use Code 'SUMMERSALE' to get it cheaper
    Dan
    2009/2010 2.0 TDIe SE
  5. Re: Brake Fluid and Coolant Flush
    Sep 2012
    Romford, UK
    Thanks for the response Dan. I just bought brake from eurocarparts with code VIP30 which gives 30% off. I can buy the Triple QX coolant, but is it as good as the Audi Coolant? As I don't replace it often, one off £20 more is fine if Audi G13 is recommended. Audi coolant is available for £40 per (4X1.5L)
  6. Re: Brake Fluid and Coolant Flush
    Jul 2007
    glasgow
    35 Post(s)
    I put in the Triple QX myself
    And I get the pre mixed stuff at 50/ 50 strength with water
  7. Re: Brake Fluid and Coolant Flush
    Sep 2012
    Romford, UK
    Thanks guys for the replies. I will get the triple QX then. I am buying a 5L and a 1L concentrate. This should be enough for 50/50 as I read somewhere that the tank capacity is 11.5L.
    Also could you recommend a brake fluid?
  8. Re: Brake Fluid and Coolant Flush
    Jul 2007
    glasgow
    35 Post(s)
    you wont get in all that amount
    don't buy the concentrate, get the 50/50 mix ........................................ then you know it wont freeze in the winter ......................... and you cant put in too much of one or the other
    I just put in the most up to date brake fluid there is on the shelf
  9. Re: Brake Fluid and Coolant Flush
    Jul 2007
    glasgow
    35 Post(s)
    as for the brake fluid .............................. I forgot about the ESP !!
    This might help http://www.caarparts.co.uk/lubricant...006/Parts.aspx to give you an idea
  10. Re: Brake Fluid and Coolant Flush
    Sep 2012
    Romford, UK
    Hi Neil I now ordered the ready mixed coolant. Just saw that eurocarparts sell G13 also for slightly higher price. Not sure what the difference is. Mine is G12, so the one you suggested should be fine.
    I have checked the Brake fluids and all the ones I put in my original post seem to be suitable. Not sure which one to go for. I read somewhere that the Pentosin DOT 4 LV is the same sold by Audi as genuine brake fluid with a different label.
  1. Question Brake fluid, coolant, powers steering fluid.... advise please
    By IlovemyVW in forum Golf MK4 - 1999 - 2004
    Last Post: 17-11-2013, 07:43 PM
  2. Brake Fluid flush & After
    By RichardSEL in forum VCDS - Help Requests
    Last Post: 26-08-2012, 10:32 AM
  3. Flush and replace brake fluid
    By ezhik in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-12-2009, 05:38 PM
  4. How To Power Steering fluid flush
    By nd32 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-11-2008, 03:29 PM
  5. Coolant and Brake fluid renewal
    By djheath in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2008, 05:27 PM
