Thread: OBDeleven first use - enabling rip CD's to MMI "Jukebo
Results 1 to 10 of 20
  1. OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Apr 2016
    Stansted
    169 Post(s)
    Hi all,
    As promised, here is my write up of how to enable the CD ripping using the information from andyhud007 captured in the Q7 (4M) Coding thread - under Stickies
    Prerequisites
    1) Android device running version 4.1 or later (I ordered a Samsung SM-T560 running v4.4.4 for about £135 to use for this and running Kodi)
    2) OBDeleven Pro (https://obdeleven.com/ - €54.99 for the device and the license and shipped from Lithuania in 6 days for me)
    3) The Android device needs to have internet access whilst programming the car
    4) Install OBDeleven app from the Play Store:
    The OBDeleven device arrives in a bag with the PRO activation code written on the outside
    The port to plug it into is above the drivers pedals (not covered which surprised me!)
    Plug the OBDeleven device in and it should light up to show it's powered up
    You then need to go to the Bluetooth menu on the Android device and pair it to the OBDeleven using 1234 as the passcode
  2. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Apr 2016
    Stansted
    169 Post(s)
    Start the OBDeleven app to get the following menu, select settings to enter the activation code for PRO
    Move the slider across and you should be prompted to add the code on the bag
    Once activated, go back to the home screen to connect
    Click connect
    Once connected, click Scan
  3. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Apr 2016
    Stansted
    169 Post(s)
    The errors are those registered by the car during use which from a bit of googling appear to be nothing to be concerned about - ignoring for this write-up
    Click on the centre to open up the next Control Units screen
    The next few posts are specific to enabling the CD ripping mod
  4. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Apr 2016
    Stansted
    169 Post(s)
    I read somewhere that when doing modifications you should have the engine running but no consumers enabled - i assumed this to be no air con and anything else that shows up on the Virtual Cockpit consumers display. Not sure if this is an issue or just best practice.
    Enabling CD Ripping using info from andyhud007's post in Q7 (4M) Coding
    Select Module (Control Unit) 5F
    Select Coding
    Select Long Coding by taping the number 1 in top right
    Use the green icon to scroll to the right to Byte 24 (opens on Byte 00)
    Once on Byte 24, you can see Bit 5 (row) is not checked
  5. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Apr 2016
    Stansted
    169 Post(s)
    Check the tick box for Bit 5 so it's enabled and click the blue tick and the bottom to apply the change
    You should now be back at the 5F Control Unit menu, this time select Adaptation
    You will then get this search menu
    If you type "copy", it will narrow the options down to the one you want and select "copy multimedia data"
  6. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Apr 2016
    Stansted
    169 Post(s)
    Optical drive is set to off
    Click on Optical drive to change this to "On" and then use the tick button to apply the change
    You then just need to reboot the MMI and you're done - see "Q7 (4M) Coding" thread under Stickies for the how-to on this.
    Hope this is useful to those about to do their first mod or those (like I was) considering whether or not to order one.
    0 2 0
  7. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Mar 2010
    37 Post(s)
    228 Post(s)
    Great Stuff SrbSQ7 and thanks for "translating" for the folk with ODBEleven.... so chuffed the coding is going to good use!
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  8. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Jul 2010
    uk
    183 Post(s)
    Fanflamingtastic!! Huge thanks I'll use same principle for needle sweep now
  9. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Jul 2010
    uk
    183 Post(s)
    How do I scan the car settings and have them sent to me by email before changing everything - can't work that out?
  10. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Jul 2010
    uk
    183 Post(s)
    Ok also want to ask how do I enable the needle sweep? Module 17 is Dash board on OBD but in there I can't see anything re needle sweep?
    However a lot of the options that say 'No' I actually have?
  1. OBDeleven news
    By wolek76 in forum Q7 - 4M Forum - 2016 -
    Last Post: 21-07-2016, 04:47 PM
  2. MMI+ Nav Google Earth error: "Not Enough Data in Memory"
    By belly buster in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-02-2014, 08:28 PM
  3. Enabling the 'Touring Mode' to appear in MMI
    By rovervampire in forum VCDS - General Questions
    Last Post: 11-05-2013, 01:39 PM
  4. Audi A6 Avant 2006 MMI "Telephone Not Installed" issue
    By moet546 in forum VCDS - Help Requests
    Last Post: 04-03-2012, 12:20 PM
  5. Question Audi A6 Avant 2006 MMI "Telephone Not Installed" issue
    By moet546 in forum In Car Entertainment
    Last Post: 24-02-2012, 11:44 AM
