Thread: Engine coolant sensor circuit high
  1. Post Engine coolant sensor circuit high
    Nov 2015
    Inverness
    Hi all
    Took my Audi A4 2.0TDI 2005 in to Audi to get a diagnostic check done and it came back with P0118 engine coolant temperature sensor 1 circuit high.
    I have changed the ect sensor with a genuine audi one before it went in to get scanned, The temperature gauge dos'nt move off the cold unless the car is booted going up hill, dosnt even reach the first notch even on a really hot day, When it does move, after you stop booting it up hill it drops back to cold again.
    The thermostat was changed as well 88degree
    What does high circuit mean?
    Any ideas on what wrong?
  2. Re: Engine coolant sensor circuit high
    Nov 2015
    Inverness
    Did read about trying this but not sure if this could cause further damage or not
    unplug the sensor and, using a fused jumper wire, jumper the two terminals of the connector together. The temperature reading should now be maxed out
    Read more at: OBD-II Trouble Code: P0118 Engine Coolant Temperature Circuit High Input
    Copyright OBD-Codes.com
  1. Replies: 0
    Last Post: 09-01-2014, 11:17 AM
  2. Engine Coolant Sensor
    By TonyMc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-01-2012, 08:50 PM
  3. Please Help Engine Coolant Temperature Sensor 1 Circuit High
    By sarah_a3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-06-2011, 09:42 PM
  4. Replies: 0
    Last Post: 24-01-2010, 12:57 PM
  5. Coolant temperature sensor reading too high
    By vlad21 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-11-2007, 01:32 PM
