Thread: iPhone charging
Results 1 to 10 of 12
  1. iPhone charging
    May 2016
    Cardiff
    Sorry, I'm sure this is probably covered in a thread somewhere but I haven't managed to find it....
    My 2016 black edition was supplied to me without any leads. Contacted dealer and he sent me 2 - one has lightning connector, the other is usb. However when plugged into socket under armrest neither of these seem to support charging of the phone. Should they?
    Im assuming I need a 12v to lightning lead but just before I buy one I thought I'd check!
    16MY 2.0 Ultra BE stronic saloon, Glacier White/Black Alcantara
  2. Re: iPhone charging
    Mar 2014
    United Kingdom
    33 Post(s)
    My phone definitely charges using the Audi-supplied cable (micro-USB cable in my case) from the USB port under the armrest. Changing the cable won't make any difference, I think. Have you tried both USB ports (with the ignition on)? There is some confusion over whether both ports function in the same way. I thought they both charged but only one would connect to the media centre - but it may be the other way round. At some point, I though Audi made both ports function in the same way. As I said, it's confusing...
  3. Re: iPhone charging
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by wwesty View Post
    The Lightening AMI lead does support charging. Check the lead is properly plugged into the phone, especially if you have a case on the phone. Also is the car recognising that the phone is connected when you press the media button and select "source". If you are going to play music from your phone via the AMI connection then you should diasable audio streaming in the bluetooth menu or the car gets confused
  4. Re: iPhone charging
    Aug 2016
    Veldegem - Belgium
    Mine also not always charges my iPhone.
    I have an A6 from 2012 with the AMI in the arm rest.
    It's just like the AMI only gives a certain amount of amperes trough.
    If i just lay down my iPhone 6S Plus and nothing is open like Spotify e.d it charges (very slow but it charges).
    When i open Spotify e.d it shows the charging emblem but it doesn't charges, it even discharge but slowly.
    My conclusion is that it only gives a certain amount of amperes trough.
  5. Re: iPhone charging
    Mar 2008
    My MY15 car will charge my iPhone 6S+ or iPad through either USB port under the armrest using a standard lightening cable.
  6. Re: iPhone charging
    Aug 2016
    Veldegem - Belgium
    Quote Originally Posted by pany View Post
    Mine is still with the Audi AMI connector, not the USB port.
  7. Re: iPhone charging
    May 2016
    Warwickshire
    Mine charges my iPhone using the AMI-lightning cable but not very fast. You also get the message about it conflicting with Bluetooth, so I've got a cigarette-lighter charger lead which seems to provide more power, is longer (so my girlfriend can Whatsapp while its charging) and allows Bluetooth music to work without a warning.
  8. Re: iPhone charging
    Aug 2016
    Veldegem - Belgium
    Quote Originally Posted by Jobbo73 View Post
    Same over here. Just plugged in a mini cigarette Dual USB Charges so it doesn't take a lot af place. My music goes over Bluetooth but the sound quality is not always as good as if you plug it in with the AMI cable.
  9. Re: iPhone charging
    May 2016
    Cardiff
    Thanks for feedback. Looks like the 12v feed is the way to go.
  10. Re: iPhone charging
    Jul 2008
    Great Wyrley, Staffordshire, UK
    Forgive my asking, but where do you connect other than via a 12V USB adapter in the auxiliary socket? I don't see anywhere else to plug in to.....
  1. Question Audi iPhone 5/5s cradle. Compatible with iPhone 5c?
    By hilly703 in forum In Car Entertainment
    Last Post: 21-08-2014, 07:33 PM
  2. MMI connector Iphone 4 to Iphone 5
    By fz0rb4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-11-2013, 09:29 AM
  3. Replies: 4
    Last Post: 01-06-2013, 03:49 PM
  4. 3g iphone not charging in Audi A4
    By baronbuzby in forum In Car Entertainment
    Last Post: 04-01-2009, 03:54 AM
  5. Replies: 3
    Last Post: 08-09-2008, 05:22 PM
