Thread: Washer Pump Fuse 2010 A6 Allroad
  1. Washer Pump Fuse 2010 A6 Allroad
    Aug 2016
    Sheffield, United Kingdom
    Hi all
    I'm hoping someone can help point me in the right direction of which fuse to check here as I cant find a definitive answer in the hand book.
    Basically I have headlamp washers working but not front or rear window. Are they two separate pumps for the front and rear or a combined unit? Also has the pump got its own fuse or relay to check?
    Thanks in advance.
  2. Re: Washer Pump Fuse 2010 A6 Allroad
    Jul 2013
    76 Post(s)
    The headlight washer pump is a separate pump.
    Both pumps can be accessed from the passenger side wheel arch by the 'A' pillar.
    Get a pump from euro car parts unless you want to robbed by VAG Group.
    ECP =£17
    VAG = £50
    Both items the same.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Washer Pump Fuse 2010 A6 Allroad
    Aug 2016
    Hi Dan
    Thanks for your response. It's the windscreen washer and rear washer pump that I have nothing from. The head light washers are working perfectly. I've checked all fuses with a tester and all are Ok. Cannot find which one is for the windscreen pump itself. Going to get a new pump from euro car parts and swap that. Hopefully it fixes the fault...
    I'm presuming that the main pump for the windscreen feeds the rear one also?
  4. Re: Washer Pump Fuse 2010 A6 Allroad
    Jul 2013
    76 Post(s)
    The windscreen washer pump feeds both the front and rear.
    its in the wheel arch at the bottom of the bottle.
    Dan
  5. Re: Washer Pump Fuse 2010 A6 Allroad
    Aug 2016
    Thanks for your input Dan. Picked up a new pump from euro car parts and issue with front and rear washers resolved. Pretty straight forward job tbh
    Out of curiosity thought I'd still like to know which fuse is for the front and rear washer pump. The headlight washer one has it's own fuse...
  6. Re: Washer Pump Fuse 2010 A6 Allroad
    130 Post(s)
    1972 Post(s)
    The washer pump does not have a dedicated fuse, the circuits are protected by the J519 onboard supply control unit which operates the pump.
  7. Re: Washer Pump Fuse 2010 A6 Allroad
    Aug 2016
    Thanks Crasher
  1. 2010 Q5 wiper/washer fault
    By Chrisd23 in forum Q5
    Last Post: 04-11-2014, 08:54 AM
  2. Please Help Wiper, washer, fuse keeps blowing
    By KieranM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-12-2013, 07:53 PM
  3. 2010 3.0ltr Allroad fuel pump noise after software upgrade
    By keithr in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-04-2012, 11:50 AM
  4. Passat 2010 fuse locations
    By beneast in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-08-2010, 02:25 PM
  5. Washer Fuse
    By 1198polo in forum Polo - Derby - Lupo - Fox
    Last Post: 12-01-2010, 06:03 PM
