Thread: Secondhand/Used EPB Control Module advice?
Results 1 to 10 of 14
  1. Secondhand/Used EPB Control Module advice?
    Aug 2016
    Godmanchester UK
    Hi all, I've run a search before posting but couldn't find specific problem and didn't want to necro an old thread!
    A couple of months ago N/S handbrake motor seized on - RAC found (surprise!) housing cracked and rusted up inside. As temporary measure they removed motor and wound back calliper - leaving EPB working fine on N/S but with Xmas tree dash, constant alarming and disabled cruise control.
    Car's been in shop (local VW specialist) having cam belt done - I sourced a new motor (£85 brand new from eBay) which they say is working fine but not receiving signal. Quoted £130 to remove centre console and £450+ for new module) so I've asked them to stop for now as I'm currently unemployed and have no money except what I have borrowed from family.
    Does anyone have experience of fitting a secondhand control unit? They are knocking around on the Bay from 30 - 80 quid and I can whip the console out no problem. I understand you need coding at every step (I don't have VAGcom) so I would hope to find a garage to actually fit it. According to the Haynes manual the module is very sensitive to knocks so I have obvious concerns about mail order.
    Can anyone offer me some friendly advice? Thanks in advance :wink:
    EDIT: I've now seen the post below mine but can't delete this one...
    EDIT 2: Passat B6/3C SE 2007 2.0TDI PD 140PS
  2. Re: Secondhand/Used EPB Control Module advice?
    Sep 2008
    SE London
    EPB modules do fail if they're operated for some time in a fault condition. Earlier ones had a flash upgrade to try and increase the threshold that this happens. Later ones do not, and appear to be more sensitive to failure.
    You don't say what year car you have so it's impossible to gauge what module you've got. But generally from '08 the modules were a "J" revision. I've got an '06MY, with the older version, that was 3C0 907 801 B. After flash it became 3C0 907 801 GX
    Irrespective of what module version you need (it'll have to be read in VCDS which is what your indie presumably has done) there's no guarantee that one sourced from eBait will be any good
    The newer "J" revision modules change from a 3c0 part number to a 3aa number
  3. Re: Secondhand/Used EPB Control Module advice?
    Aug 2016
    Godmanchester UK
    Thanks Richard - I've edited the original post with the car details (doh!) it's a 2007 SE 2.0TDI PD 140PS
    My local specialist have quoted £60 to fit and code a used module if I whip the centre console out which seems fair - guess I'll have to try my luck with eBay...
  4. Re: Secondhand/Used EPB Control Module advice?
    Sep 2008
    SE London
    With an '07MY you should only change like for like until you flash update.
    The difference between a "B" and a "J" is first's a 23 byte module but second is a 30 byte one
    Older cars may not accept a 30 byte module.
    If your replacement's a "B" then get it flashed to "GX" ASAP --
    This link for a US Technical Service Bulletin (TSB) is for the EPB controller flash update US recall. Had it installed in the UK, but you have to pay. A VAG-trained indi workshop with VAS computer that connects to VW’s mainframe will charge 1 hour +VAT — typically £60 +VAT (Volks Autos, Sutton). VW main agent (Beadles, Sevenoaks) wanted two hours. This software update is relevant only to specific versions of EPB controller:
    http://nateronline.com/Technical_Bul...park_brake.pdf
    1 1 0
  5. Re: Secondhand/Used EPB Control Module advice?
    Aug 2016
    Godmanchester UK
    Well a Bay special's on its way - worth a punt at £20 'guaranteed working correctly' and seller with good feedback who will package it properly!
    Again thanks for your help - much appreciated
  6. Re: Secondhand/Used EPB Control Module advice?
    Apr 2007
    France
    12 Post(s)
    Let us know how you get on?
    1996 Laguna 2.2D
    1977 MGB roadster
  7. Re: Secondhand/Used EPB Control Module advice?
    Norfolk
    Has the supply to the epb module been checked? The motors are fused.
  8. Re: Secondhand/Used EPB Control Module advice?
    Nov 2006
    derbyshire
    Hi. Just gonna bomb into this thread. I have a 58 plate passat with error code 02845 (brake system warning lamp, short to ground) in Park brake module and have read that this is a software error. Now would a reprogram help or am I just as well going for replacement and if so what module would work in mine? Am I just as well getting like for like. Thanks
    Sent from my SM-G935F using Tapatalk
  9. Re: Secondhand/Used EPB Control Module advice?
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Does your EPB button illuminate still when you cycle the brakes on? If it does not, replace the button (for a C version) as the diode inside has blown.
    Mad Mitch
  10. Re: Secondhand/Used EPB Control Module advice?
    Nov 2006
    derbyshire
    Hi. Button works fine and illuminates when park brake is on. Was a new switch fitted last year. Thanks
  1. EPB Module Failure, which part suffix/revision?
    By mercedeslimos in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-02-2020, 12:19 AM
  2. Replies: 2
    Last Post: 17-08-2012, 08:00 PM
  3. Need advice please: Engine Control Module can not communicate
    By chips in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2012, 09:53 PM
  4. Remote key fob,secondhand or brandnew??Advice sought please
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2008, 09:36 AM
  5. A6 secondhand advice please
    By 2pt joe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-09-2008, 01:38 PM
