Thread: RNS510 Upgrade software
Results 1 to 8 of 8
  1. RNS510 Upgrade software
    Dec 2007
    My car is now 5 years old and (touch wood) the GPS Navigation still works very well but it could do with updating (eg it does not accept post code destinations and the maps are for 2010).
    Has anyone experience with updating the system with a VW supplied disc? I am slightly apprehensive as I woudn't be too happy messing around with a 5 year old laptop that was performing OK.
    Thanks for any info.
    Mike
  2. Re: RNS510 Upgrade software
    Sep 2008
    SE London
    To show current map version press and hold the set up button for 10 seconds, then select version information
    Dealer will then tell you what's latest available according to your RNS510 version.
    AFAICR postcodes were added sometime later than 2011 (?)
    There are also firmware upgrades available, on the same update. Would have to know what your model number is to say what's latest.
    3C0 035 684E/F and 3C8 035 684E/F -- end of 2011/early 2012 RNS-510 release unit
  3. Re: RNS510 Upgrade software
    Dec 2007
    I am unable to find the version by pressing the Set Up button for more than 10 seconds. I assume my version is pre this facility (car built 2010).
    The local VW guy, who seems reasonably knowledgeable, said I can just put in a CD for latest maps (mine is Europe West V6.1).
    Would I need to update the firmware for the system?
  4. Re: RNS510 Upgrade software
    Jul 2008
    Blackburn
    My Passat is same age as yours, 60 reg. When I took it in to my local VW to have the emissions update done, I asked about a Nav update, they said the latest disc would cost £160. I said not to bother at that cost.
    VW UP! High UP! 74 bhp 2016 reg
  5. Re: RNS510 Upgrade software
    Dec 2007
    Thanks frank.
    As a matter of interest how does the car run after the emissions update?
    Mike
  6. Re: RNS510 Upgrade software
    Mar 2014
    Northampton, United Kingdom
    I'm member of GPSUnderground which has maps and firmware updates for nearly every GPS unit in the world.
    It also has sets for RNS510 (Firmware as well as Maps)
    Very trusted source for anything GPS related.
    I've been dealing with maps for a while myself so if you struggle to get this working or need any assistance I can help.
    I'm in Northampton so if you aren't too far away can also arrange some time for you to come over. Will see how can I help with your struggles
  7. Re: RNS510 Upgrade software
    Jul 2008
    Blackburn
    Quote Originally Posted by mike6265 View Post
    Thanks frank.
    Mike
    To be honest, I can't say I've noticed any difference in performance or fuel usage.
  8. Re: RNS510 Upgrade software
    Everywhere
    Hi Guys,
    Would anyone have links to latest firmware and maps for my 2009 vw passat B6. Rns510 details below from vcds, it's the older version with info button top right.
    Tia
    Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
    Part No SW: 1T0 035 680 B HW: 1T0 035 680 B
    Component: RNS-MID H11 1200
    Revision: AB001001 Serial number: VWZ6Z7J6258076
    Coding: 040004000400008200
    Shop #: WSC 00028 028 00001
    VCID: 2D5AFF5E7425842702-8078
    Sent from my CLT-L09 using Tapatalk
  1. RNS510 upgrade
    By BobbyBrown in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-04-2015, 12:26 PM
