Thread: Audi a4 BLB and BRE difference
  1. Audi a4 BLB and BRE difference
    Aug 2016
    uk
    Hi there,
    Currently I had a problem with my engine (BRE) Audi a4 2.0. tdi. 103kw. The engine needs to be replaced. I found similar engine from audi A6, however its got different code (BLB). Is it big difference between them? Can I still put BLB instead of BRE? Kind regards
  2. Re: Audi a4 BLB and BRE difference
    May 2012
    Everywhere
    308 Post(s)
    Definitely not BLB as it has the double trouble of a chain driven twin Lancaster balancer shafts .
    It has to be an 2.0 tdi engine code which as oe has the old style reliable 1.9 tdi chain driven oil pump or a gear driven twin Lancaster balancer shaft that has had the 100mm hex key drive and remanufactured modified balancer shaft #2 done .
  3. Re: Audi a4 BLB and BRE difference
    Aug 2016
    uk
    Thanks,
    Anyway, I just want to know if these two engines are interchangeable. If not, is it any other engine code consimilar to BRE.
  1. help please audi a6 2.0 tdi BRE engine drive me crazy
    By Master Sylvain in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2014, 05:19 PM
  2. Is it possible for BLB Oil Pump Chain Failure in a 2007 A6 2.0 tdi BRE Engine?
    By James1965 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-03-2011, 05:29 PM
  3. BLB to BRE Engine
    By Andrea-Kai in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-02-2011, 09:10 PM
  4. will a bre code go in my blb
    By tonty42 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-06-2010, 05:07 PM
  5. a4 blb engine blown will a bre engine fit?
    By mrfq400 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-01-2010, 09:30 PM
