Thread: HELP ASAP!! Audi A3 8L Speakers.
  1. HELP ASAP!! Audi A3 8L Speakers.
    Aug 2016
    Leeds
    Will these speakers fit as a replacement for my drivers and passenger side door speakers?
    www.halfords.com/technology/car-audio/car-speakers/vibe-slick-5-v5-co-axial-speakers
    Vibe Slick 6" V5 Co-Axial Car Speak...
    Secondly which are better?!
  2. Re: HELP ASAP!! Audi A3 8L Speakers.
    Oct 2005
    Welcome to VWAF
    BOSE or not?
    If you're replacing them to get a better sound the best thing you can do is, imho, change the head unit first.
    Front speakers are 13cm/5.25" with 1" tweeters but the bass driver needs to be shallow so as not to foul the window. The factory speakers are riveted in so you'll either need to use those nasty plastic adapters or make up some MDF ones of your own.
  3. Re: HELP ASAP!! Audi A3 8L Speakers.
    Aug 2016
    Leeds
    Thank you!
    Unfortunately not Bose!
    Changed the head unit, does new wiring need to be done or is it all fairly plug and play?
    Thanks,
  4. Re: HELP ASAP!! Audi A3 8L Speakers.
    Oct 2005
    Haven't done an A3 myself but as you've not got BOSE it should be fairly straight forward.
    You'll have to clip the factory plugs and crimp on new connectors though.
  5. Re: HELP ASAP!! Audi A3 8L Speakers.
    May 2012
    Everywhere
    308 Post(s)
    Plastic adapters aren't the end of the world , they do the job .
    Often as a kit an Autoleads - sak plastic adapters with a wiring harness will be plug and play .
    What's the permitted mounting depth to clear the window ?
  1. Replies: 5
    Last Post: 15-05-2013, 06:15 PM
  2. Audi 4 B6 sPEAKERS
    By vernon7026 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-10-2012, 09:32 AM
  3. Question Audi A4 B6 2.5 TDI Central Locking Problem(HELP NEEDED ASAP PLZ)
    By SHAZA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-09-2011, 11:08 PM
  4. Replies: 0
    Last Post: 08-06-2008, 02:03 AM
  5. new member advice plz asap on audi a8
    By gavnkel in forum New Member Introductions
    Last Post: 12-02-2008, 12:03 AM
