Thread: 1.9TDi PD130 remap
Results 1 to 10 of 16
  1. 1.9TDi PD130 remap
    Aug 2016
    GB
    Hi, does anyone own a PD130 engine at all?
    I've just got the car and I'm using it for towing. I've used it once for a 170mile tow and for saying it's done 175k it's still going alright.
    Now my issue is, power wise it lacks when pulling, once up to speed everything is pretty much as it should be. I've come to the conclusion that a remap is in order, has anyone done this to an Alhambra and how well do they cope?
    Sent from my Y635-L01 using Tapatalk
  2. Re: 1.9TDi PD130 remap
    Jul 2015
    Staffs
    46 Post(s)
    I personally wouldn't remap a 175k car.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: 1.9TDi PD130 remap
    May 2012
    Everywhere
    308 Post(s)
    You are forgetting that the 1.9 130 PD is a legend that handles 300k+ with annual PD oil changes .
  4. Re: 1.9TDi PD130 remap
    Dec 2013
    From - Walney Island, Cumbria, Live in: Larkhill, Wiltshire
    11 Post(s)
    Thats not even run in yet... My Passat just ticked over 130k this week. Pulls like a train.. Go for it, one thing you will have to be wary of is the clutch and DMF at that mileage, it's probably been changed but some make it up over 200k I hear. If you get a proper custom map done, a decent mapper should take the torque spikes out and make it smooth which will help loads. Engine was built for it. I'm sure dark side do parts to help get it up and over 350bhp? (Could be wrong so don't quote me). Possibly one of the best Diesel engines in history. And easy enough to work on if you've got a longitudinal like the Passat lol.
    Mini
    1 1 0
  5. Re: 1.9TDi PD130 remap
    May 2012
    Everywhere
    308 Post(s)
    Or get a generic with a reduced torque clutch friendly map that has the flatest and widest torque curve ever seen for a 1.9 130 PD
    1 1 0
  6. Re: 1.9TDi PD130 remap
    Dec 2013
    11 Post(s)
    If I'm not mistaken, the standard 130pd sport puts out more torque than the 2.8 V6 petrol? (I never said it was a faster car, OEM torque spec is 315 where 2.8 is 280) All PD 130's are getting on now but rarely hear of them failing. It's all about maintenance. Mine was hammered and treat like crap for 8 years before I got it... Had t three years now and runs like new... Just the rest of the car I'm chasing parts on
  7. Re: 1.9TDi PD130 remap
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Check your egr and intake manifold for fouling, likely to be pretty bad if they haven't been cleaned yet. Also fuel filter recently changed, MAF, VNT working ok ? Lots of things to check before considering a remap. I can't see much point remapping if your egr is still fouled up or turbo vnt not working properly.
  8. Re: 1.9TDi PD130 remap
    Aug 2016
    GB
    Turbo, egr and injectors have all been cleaned, fresh oil and filters all round. The only thing I'm stuck with before doing the remap is the oil temperature. Now I've got the gage on the dash (as standard) and it did work until I changed the oil pressure switch(sensor) and oil level sensor. Since then I get no oil read out.
    It appears it has no effect on the car as yet but I am hesitant to actually open it up.
    Is what I changed a temp sensor or the pressure switch. It sits at the bottom of the oil filter housing.
  9. Re: 1.9TDi PD130 remap
    Jul 2015
    Staffs
    46 Post(s)
    I know the engine can take it. I ran a PD130 for 6 years. My concern is the drivetrain-clutch/flywheel/shafts on an already heavy motor.
    Ian
  10. Re: 1.9TDi PD130 remap
    Aug 2016
    GB
    I'm not no speed demon, its more for the mpg and for when I tow (2 maybe 3 times a year for around 100 miles).
    I'm not aiming for a Santa pod car (although it would be nice 😂 ) and any sign of failure to the clutch/flywheel it would be changed and upgraded.
    My concern was more the engine itself.
    Still need to investigate the oil temperature and why the gage is not actually reading.
  1. Vw pd130 remap copy to audi pd130???
    By Martynas26 in forum 1.9TDi - Engine
    Last Post: 02-09-2015, 10:15 AM
  2. 1.9TDI PD130 Aux heater gurgling
    By matthewgdavies in forum Alhambra
    Last Post: 06-04-2012, 10:43 PM
  3. Please Help Engine Idle issue with A3 1.9TDi PD130
    By michaelab in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-04-2010, 05:33 PM
  4. Help! Cold start problem 1.9TDi (PD130)
    By sinso in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2007, 06:41 PM
  5. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
